[OpenLayers-Users] JSON format does not work in Protocol.WFS
paweluz paweluz at o2.pl
Wed Apr 14 02:32:21 EDT 2010
Hi Andreas
Unfortunately it still does not work. My code for protocol looks now like
this:
        protocol: new OpenLayers.Protocol.WFS({
            version: "1.1.0",
            srsName: "EPSG:4326",
            url: "http://localhost/geoserver2_0_1/wfs",
            featureNS :  "http://www.openplans.org/topp",
            featureType: "bazadanych",
            geometryName: "the_geom",
	    outputFormat: "json",
            readFormat: new OpenLayers.Format.GeoJSON() ,
            schema:
"http://localhost/geoserver2_0_1/wfs/DescribeFeatureType?version=1.1.0&typename=topp:bazadanych",
	    featurePrefix: "topp"
I changed line you suggested but still in firebug I can see only GML file as
RESPONSE. Are you sure that this is the way I should define the
outputFormat. In here http://trac.openlayers.org/ticket/2107#comment:11 I
found that my old version was correct. Or maybe in 2.9 version of OL your
version is correct.... What else should I try??
Regards,
Poul
View this message in context: http://n2.nabble.com/JSON-format-does-not-work-in-Protocol-WFS-tp4894449p4900100.html
