[OpenLayers-Users] Custom Toolbar
Andrew Haigh
haighaj+ollist at googlemail.com
Thu Apr 15 08:53:39 EDT 2010
OpenLayers 2.9 RC 2
I'm attempting to create a custom tool and toolbar class but I seem to be
running into an issue with the custom toolbar.
Here is my code below
ZoomToAgreementExtent = OpenLayers.Class(OpenLayers.Control, {
type: OpenLayers.Control.TYPE_BUTTON,
trigger: function() {
if (this.map) {
alert('this is a test');
CLASS_NAME: "ZoomToAgreementExtent"
ApplicationToolbar = OpenLayers.Class(OpenLayers.Control.Panel, {
initialize: function(options) {
OpenLayers.Control.Panel.prototype.initialize.apply(this,
[options]);
this.addControls([
new OpenLayers.Control.Navigation(),
new OpenLayers.Control.ZoomBox(),
new ZoomToAgreementExtent()
draw: function() {
var div = OpenLayers.Control.Panel.prototype.draw.apply(this,
arguments);
this.activateControl(this.controls[0]);
return div;
CLASS_NAME: "ApplicationToolbar"
Then on my map init method I do this:
var appToolbar = new ApplicationToolbar();
map.addControl(appToolbar);
The ZoomToAgreementExtent control seems to work fine but when I try and add
the ApplicationToolbar (which I based on the NavToolbar) I get the following
error in FireBug:
this.initialize is undefined in OpenLayers-2.9-rc2.js on line 117.
I assume that there isn't a bug in the Open Layers library but instead there
is something wrong with my code.
Any ideas?
Thanks
Andrew
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100415/b18143be/attachment.html
