[OpenLayers-Users] How to set map size?
Eric Lemoine
eric.lemoine at camptocamp.com
Sun Apr 18 08:22:11 EDT 2010
On Wednesday, April 14, 2010, Dennis Janezic / TerraTransfer GmbH
<d.janezic at terratransfer.de> wrote:
> Hello at all,
Hi.
> there is a problem I could not really solve by myself, so it would be
> very nice if someone could give me a hint.
> If the question has already been posted, please excuse me. I have
> searched the internet, but i cannot find what I am exactly searching for...
> So what I want to know from you is how to resize the map. I am using the
> open layers map as child of an window component (it's an qooxdoo
> application). Resizing the window still resizes the map (visual), but
> when I call the "getSize()" - method, the old size of the map is
> returned. (Thats a little bit strange for my understanding...) The
> problem which results is that not all tiles are rendered when enlarging
> the window...
> I have figured out setting the size of the map manually is possible by
> calling
> map.size.h = 300;
Don't do that, that will lead to issues.
> After calling this command, the "getSize()" method returns the new size
> (300), but it does not lead to a solution. When calling the
> "updateSize()" method, open layers compares "getCurrentSize()" and
> "getSize()" and replaces the new size (300) with the old one (still
> stored under "getCurrentSize()") once again and the tiles still aren't
> rendered?!?
map.updateSize is what should be called. And getCurrentSize, called by
updateSize, should return the new size. If that's not what you're
observing then there's an issue somewhere.
Cheers,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
