[OpenLayers-Users] WMS GetFeatureInfo not returning results
Tobias Luetticke
Tobias.Luetticke at justice.govt.nz
Sun Apr 18 19:12:00 EDT 2010
Hi there
Sorry for the late answer, but your reply was caught in the spam
filter.
I finally figured this one out, at least sort of. It must have been my
GeoServer that was messed up in some non-obvious way as the layer
preview did work on other systems. I reinstalled and now it works fine.
A case for the X-files, I'm afraid.
BTW, text/plain didn't change the fact that no data was coming back,
but instead of sending an empty table it presented a message that clear
and along the lines of "No data found".
Cheers
Tobias
>>> On 13/04/2010 at 6:31 p.m., Sarah Schuessler <sarah_flip at yahoo.de>
wrote:
> Hi,
> did you tried using info_format=text/plain?
> I had same problem some weeks ago and I think with that I get info
back.
> HTH
> best regards
> Sarah
> ________________________________
> Von: Tobias Luetticke <Tobias.Luetticke at justice.govt.nz>
> An: users at openlayers.org
> Gesendet: Dienstag, den 13. April 2010, 6:32:01 Uhr
> Betreff: [OpenLayers-Users] WMS GetFeatureInfo not returning results
> Hi
> I'm trying to get information back by executing a WMS GetFeatureInfo
> request, but without success. I am using the GeoServer Layer Preview
function
> that in turn uses OpenLayers.
> When I click on a feature on the map eg the following request is sent
> (copied from Firebug):
http://localhost:8080/geoserver/wms?REQUEST=GetFeatureInfo&EXCEPTIONS=applica
tion%2Fvnd.ogc.se_xml&BBOX=1929381.381188%2C5592303.911446%2C1941522.166813%2C
5603614.760554&X=372&Y=170&INFO_FORMAT=text%2Fhtml&QUERY_LAYERS=test%3ATL_STANDAR
D_PARCEL&FEATURE_COUNT=50&Srs=EPSG%3A2193&Layers=test%3ATL_STANDARD_PARCEL&Styles
> =&WIDTH=512&HEIGHT=477&format=image%2Fpng
> The GeoServer logs confirm that it receives the request and accesses
the
> datastore. It also talks about writing to an OutputStream, but since
I don't
> get any feature info back I can't judge whether that's all good or
not.
> Checking Firebug for the response it confirms that HTML is streamed
back from
> GeoServer, just the table that should contain the feature info is
missing.
> My configuration is
> * GeoServer 2.0.1
> * OpenLayers 2.8
> * All running locally in my development sandbox
> * Data coming from a shapefile data store
> * GeoServer layer set to EPSG:2193 as declared SRS with SRS handling
to
> "force declared".
> I have confirmed with ArcGIS Explorer that the shape file contains
the
> information I'm after. When I export data from GeoServer (again Layer
> preview) as GML the attributes are in there. There doesn't seem to be
> anything horribly wrong as the borwser/GeoServer roundtrip happens
> successfully. I guess somewhere I wired things wrongly together such
that the
> request comes back empty.
> Oddly enough, the GeoServer provided layer of US States (that uses
> shapefiles also) shows the same behaviour. However, on another
> installation that shows the same configuration data comes back and a
table
> showing the feature information is displayed.
> What am I missing? Any ideas much appreciated.
> Cheers
> Tobias
> This e-mail message and attachments do not necessarily reflect the
views of
> the New Zealand Ministry of Justice and may contain
> information that is confidential and may be subject to legal
privilege. If
> you
> are not the intended recipient, you are hereby notified that you must
not
> use,
> disseminate, distribute or copy this e-mail message or its
attachments. If
> you
> received this message in error, please notify the Ministry of Justice
> by telephone (call collect: 00-64-4-918-8800) or return the
> original message to us by e-mail, and destroy any copies.
> Thank you.
> _________________
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> __________________________________________________
> Do You Yahoo!?
> Sie sind Spam leid? Yahoo! Mail verfügt über einen herausragenden
Schutz
> gegen Massenmails.
> http://mail.yahoo.com
This e-mail message and attachments do not necessarily reflect the views of
information that is confidential and may be subject to legal privilege. If you
are not the intended recipient, you are hereby notified that you must not use,
disseminate, distribute or copy this e-mail message or its attachments. If you
Thank you.
