[OpenLayers-Users] Generated icons in a vector layer based on KML
Slawomir Messner
slawomir.messner at staff.uni-marburg.de
Mon Apr 19 07:27:31 EDT 2010
I want to add a vector layer with a generated KML file with generated
icons. Both are generated together and then the KML-file is sent to the
client. Then when the kml-file is loaded as a layer OL tries to get the
icon files form a ASP handler, they are not generated by the handler
they are already existing at the time when OL requests them. The
icon-files are generated only once on a second call the already existing
files are sent to the client.
So, now the problem: When I first call the layer no icons are visible on
the second and the next tries the icons are visible.
1. I looked into firebug and all the icons are sent to the client.
2. Firebug tells me that the icons are there but the width and height
are 0 when I change them the icon is visible.
3. I looked into the Format.KML and Renderer.SVG and they told me the
width is 32x32 in the setStyle-function, I suppose it's the default
value of OL my icons are smaller.
4. I saw in 3 you parse the w/h tags of icon in kml so I set them, but
it doesn't help the w/h in firebug says it's both 0.
5. When I tried 3 and 4 I used some alerts and when I paste them into
setStyle like this:
//if(this.test < 10)
//alert("1 : "+style.graphicWidth +" :
"+style.graphicHeight);
var width = style.graphicWidth || style.graphicHeight;
var height = style.graphicHeight || style.graphicWidth;
//alert("2 : "+width+" : "+height);
width = width ? width : style.pointRadius*2;
height = height ? height : style.pointRadius*2;
//alert("3 : "+width+" : "+height);
this.test++;
a random number of icons appeared on the map.
6. I tried to delay the sending of the kml-file but no change.
7. I tried all if the icon-files are locked or something but it doesn't
seem so and if you remember firebug says the files are ok.
8. I debugged the handler, but the files are ok and no hidden exception
and the icons are not visible after a breakpoint, not like with the alert.
So that's all from me, anyone an idea?
Thanks
Slawomir
Slawomir Messner
Forschungszentrum "Deutscher Sprachatlas"
06421-28-24981
