[OpenLayers-Users] Projection problem
Sarah Schuessler
sarah_flip at yahoo.de
Tue Apr 20 11:50:01 EDT 2010
just an idea of mine:
do you use 'sphericalMercator': true at your google layer?
best regards
Sarah
Von: José Angel Rodríguez Leyva <jar.cub at gmail.com>
An: users at openlayers.org
Gesendet: Dienstag, den 20. April 2010, 17:33:46 Uhr
Betreff: [OpenLayers-Users] Projection problem
I'm using Postgres/PostGIS with Geoserver and OpenLayer on Windows for
represent a set of points and polygons layers over Google Maps base
layers. All the spatial data are in EPSG:4326 projections, since the
WKT geometries on postgres's tables, the geometry_columns's register
for postgis, and the layer setup in geoserver. When I combine the WMS
layers from geoserver with anyone of Google all my features get
displaced notably to the north; especially in bigger scales.
I know that Google Maps projection is EPSG:900913 and thats why I
tried to reproject the Geoserver layers to get all in the same
reference. Sometimes I got the same result and others got nothing. One
of this tries were to use the projection and displayPorjection
properties in this way:
projection: new OpenLayers.Projection("EPSG:900913"),
displayProjection: new OpenLayers.Projection("EPSG:4326"),
But isn't clear for me if I had to reproject the layers from Geoserver
to 900913 of just left like it is. So I tried some configs variants
between declared and native (changing at the db source) SRS property
in layer definition. No one works. Now I don't use displayProjection
until I can understand good enought how it works.
This is a snapshot of my data and config in Postgress
- The geometries were inserted with a sentence like this:
INSERT INTO "TABLE"("theGeom") (geomfromtext('POINT(-1.6556196
42.8149421)', 4326));
- and geometry_columns updated:
17422;"pg_catalog";"public";"TABLE";"theGeom";2;4326;"POINT"
Then I have used in Geoserver the configurations variants I said
before. and 'srs: "EPSG:4326"' in property of layer in Openlayers.
I think that I missed another config property or I'm not using the
right projection in some property, but now In don't know what to do.
Thanks in advanced,
José A.R.
o.o
..o
O..
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100420/05268bc8/attachment.html
