[OpenLayers-Users] IE shows only one feature on the map,
but the vml nodes exist
J.Schumann
j_schumann at gmx.de
Thu Apr 22 11:12:36 EDT 2010
Ok, I found the problem, but the solution is inacceptable:
The visible feature was the only one with graphicXOffset and the other
offsets set to 0, all others had offsets defined in the stylemap. When I
force all offsets for all features to zero all are visible.
Is this a known problem with the VML renderer? Or is it a problem within the
IE?
Regards, JS
View this message in context: http://osgeo-org.1803224.n2.nabble.com/IE-shows-only-one-feature-on-the-map-but-the-vml-nodes-exist-tp4943165p4943315.html
