[OpenLayers-Users] Correct way to replace the layers in a map
with a completely new set?
Phil Scadden
p.scadden at gns.cri.nz
Sun Apr 25 18:59:23 EDT 2010
> how do you "destroy" the layers? Do you use map.removeLayer()? You could
> add the new baselayer first and then remove the old ones. But without
> some example code which shows the problem it is difficult to help you ...
Yes, I am using remove layers, but each layer removal triggers a heap of
event processing that would be
more appropriate if done in one go - I was looking for a
"removeAllLayers" type method that suppressed unnecessary event calling.
I have done the adding new layers first - its when it decides that the
one of new
layers is the new baselayer before it has finished removing all the old
layers that triggers the problem. I'll see if I can nail exactly what
causes the issue. Perhaps I need to remove all non-baselayers first,
then rip through and remove the baselayers.
Phil Scadden, Senior Scientist GNS Science Ltd 764 Cumberland St,
Private Bag 1930, Dunedin, New Zealand Ph +64 3 4799663, fax +64 3 477 5232
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
