[OpenLayers-Users] unselect did not work
Sarah Schuessler sarah_flip at yahoo.de
Tue Apr 27 03:57:27 EDT 2010
Hi Arnd,
thanks for your answer!
Please read below.
i'm not sure, why you need a layer for your selected
feature. Why not use the selectFeatureControl on the wfs
layer.
I use my Control.SelectFeature with my wfs layer(wfs2)- or don`t I use the event right? (event.register instead of events.on). I get along with this example: http://dev.openlayers.org/releases/OpenLayers-2.9/examples/getfeature-wfs.html to get back a visual selecting for the user and get back some information about the selected feature.
About your question.
The problem is the feature object. You add not a new
feature to a new layer. Instead it seems, that you move the selected
feature from the wfs layer  to the new layer. That means
wfs.event.on("unselected") cann't work, because your selectFeatureControl works
only for the wfs layer.
Yes I thought something like that, but could not manage to solve this. Thanks for your example!
Use a
clone of the feature and remove the only feature on your select
layer.
    layerWFS.events.on({'featureselected':
function(feature){
selectLayer.addFeatures([feature.feature.clone()]);
//selectLayer.addFeatures([feature.feature]);
alert(this.selectedFeatures.length);
'featureunselected':
function(feature){
selectLayer.removeFeatures([selectLayer.features[0]]);
//selectLayer.removeFeatures([feature.feature]);
alert(this.selectedFeatures.length + " -
unselected");
A bit confusing is also the style you add as default
style to the select layer. It looks like you select a feature on the wfs layer,
but it's really the not selected feature on the select
layer.
So I have to register a select style to my wfs layer and cancel select layer, am I right?
best regards
Sarah
Arnd
 Von: users-bounces at openlayers.org
[mailto:users-bounces at openlayers.org] Im Auftrag von Sarah
Schuessler
Gesendet: Montag, 26. April 2010 10:28
An: users at openlayers.org
Betreff: [OpenLayers-Users] unselect did not
work
Hi list,
I try to use Control.SelectFeature but I can`t unselect
(selection layer does not get removed). Here is my code:
var selectFeature =
new OpenLayers.Control.SelectFeature(wfs2, {clickout: true, multiple: false,
hover: false, toggle:false, toggleKey: "shiftKey", box: true, multipleKey:
"ctrlKey"});
var wfs2 = new OpenLayers.Layer.Vector("WFS_Waldschutz",
{ styleMap: styleMap,
         strategies: [new
OpenLayers.Strategy.Fixed()],
         protocol: new
OpenLayers.Protocol.WFS({
           url: "http://myserver:81/geoserver/wfs?service=wfs",
        featureNS: "http://mycomp.org",
        featureType: "mylayer",
    geometryName: "SHAPE",
srsName: "EPSG:4326",
            version: "1.1.0"
projection: new OpenLayers.Projection("EPSG:4326")
wfs2.events.on({'featureselected': function(feature){
select.addFeatures([feature.feature]);
'featureunselected': function(feature){
select.removeFeatures([feature.feature]);
alert("unselected");
var select = new
OpenLayers.Layer.Vector("Selection", {
    styleMap: new
OpenLayers.Style(OpenLayers.Feature.Vector.style["select"]),
displayInLayerSwitcher: true, visibility: true});
featureselected works
(at firebug I can see that my app does not get to this break point). What`s
wrong?
Thank you for any hints.
best
regards
Sarah
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100427/b2a2ebbf/attachment.html
