[OpenLayers-Users] control.SelectFeature
sunny74
sb.ray at hotmail.com
Tue Apr 27 07:06:02 EDT 2010
Hi Sarah,
thanks for your reply.
If I look at the spatial filter documentation
http://dev.openlayers.org/releases/OpenLayers-2.8/doc/apidocs/files/OpenLayers/Filter/Spatial-js.html
I find that there are 3 things that need to be mentioned in all except the
DWITHIN filter.
What do I specify for 1) property 2) value parameter of the Spatial Filter
constructor.
the value parameter requires either bounds or the geometry.How do I get
that for the box I am creating?
My code is:
control = new OpenLayers.Control.GetFeature({
protocol: OpenLayers.Protocol.WFS({
formatOptions: {
outputFormat: "text/xml"
url:
"/cgi-bin/mapserv.exe?map=c:/ms4w/apache/htdocs/Shape/Rail_wfs.map",
featureType: 'RailwayStations',
featurePrefix: 'ms',
geometryName: 'msgeometry',
maxFeatures: 100,
var defaultFilter: new OpenLayers.Filter.Spatial({
type: OpenLayers.Filter.Spatial.INTERSECTS}, {value: bounds})
box: true,
multipleKey: "shiftKey"
Pls change the defaultFilter so that it gets the above two parameters.
What is the purpose of DWITHIN,BBOX Filter?
There is no Filter by the name of "buffer"?
Thanks a lot for your help.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/control-SelectFeature-tp4930933p4968003.html
