[OpenLayers-Users] Spatial Filter parameter for WFS GetFeature
bartvde at osgis.nl
bartvde at osgis.nl
Tue Apr 27 09:56:07 EDT 2010
The control fills in the value as I said before.
Please install Firebug and check the request generated by OpenLayers and
sent to your WFS.
Bart
> Hi Bart,
> I tried both the Intersects as well as the WITHIN Filter with the
> filtertype
> as suggested by you.
> In both cases I get the same result i.e Intersects does not give me only
> the
> intersecting features and Within does not give me only the features
> completely within the selection.
> It could be possibly because I am not able to give the property and value
> PARAMETERS and so it doesn't work.
> So I think it is important to provide the two values.
> So pls provide the code so that it gets the required values.
> Thanks.
> http://osgeo-org.1803224.n2.nabble.com/Spatial-Filter-parameter-for-WFS-GetFeature-tp4968446p4968690.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
