[OpenLayers-Users] Vector rotation issues with 2.9
pedro hernandez
pedrohernandez830 at gmail.com
Wed Apr 28 05:20:52 EDT 2010
In my case it works. Thanks a lot Andreas!!!
On Tue, Apr 27, 2010 at 9:43 PM, Andreas Hocevar <ahocevar at opengeo.org>wrote:
> Hi,
> On Apr 27, 2010, at 15:56 , Lennox Antoine wrote:
> > I tried 2.9 and I ran into similar issues as well. I finally got around
> to stripping it down, so here are two simple examples showing it :
> > 2.8 : http://vizure.net/temp/ol/rotation_2_8.html
> > 2.9 : http://vizure.net/temp/ol/rotation_2_9.html
> Thanks Lennox for putting this together. Your efforts finally made a fix
> possible. See http://trac.openlayers.org/ticket/2596.
> John, this should also fix your issue. Can you please verify?
> Regards,
> Andreas.
> > Both are exactly the same, except for which version of the library is in
> use.
> > In 2.8, click the icon, then drag it around. Everything works fine.
> > In 2.9, click the icon, then try to drag it around. For me it starts to
> rotate and move in the opposite direction. If I zoom in, it also goes to
> random places and does not stay where it's pinned.
> > Lennox
> > On Tue, Apr 27, 2010 at 8:30 AM, pedro hernandez <
> pedrohernandez830 at gmail.com> wrote:
> > Something similar happens to me when I tried 2.9 version.
> > I'm using Vector Layer with one vector of Geometry Points. If I use
> circle in graphicName of Style Map it puts in a good position but If I
> instead I use triangle with rotation propierty it puts in a bad postion.
> > In my case this happens in Mozilla Firefox (I'm using 3.5 version) and
> not in IE8.
> > On Tue, Apr 27, 2010 at 4:14 AM, Robert Sanson <SansonR at asurequality.com>
> wrote:
> > It looks to me like the labels are keeping their correct geographical
> positions, but the vector symbols (arrows) are not.
> > Robert
> > >>> John McGuire <jamcguir at ncsu.edu> 27/04/2010 7:22 a.m. >>>
> > All,
> > I am creating an interface to visualization weather information.
> > However, within the past week, we have noticed that when a user zooms in
> > and out with wind arrows drawn, the vector is separate from its label,
> > and nowhere near its intended direction. I have found that v2.8 does not
> > have this issue. Playing with the code, it seems that the rotation in
> > v2.9 is the problem, and also exists for the default shape of triangle.
> > If anyone would have any further insight to this problem, I would be
> > greatly appreciative.
> > I have included links below to demonstrate the difference.
> > 2.9 map:
> > http://sco-server6.meas.ncsu.edu/webtest/workspace/cronos/map/?ol=2.9
> > 2.8 map: http://sco-server6.meas.ncsu.edu/webtest/workspace/cronos/map/
> > Thank you all for your help,
> > -John
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> > This message has been scanned for malware by SurfControl plc.
> www.surfcontrol.com
> > Users mailing list
> > Users mailing list
> > Users mailing list
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100428/de3dd6f2/attachment.html
