[OpenLayers-Users] scaleline in lon/lat projection
Andreas Hocevar
ahocevar at opengeo.org
Wed Apr 28 07:46:35 EDT 2010
in OpenLayers 2.9, you can instantiate the ScaleLine control with the geodesic option set to true:
new OpenLayers.Control.ScaleLine({
geodesic: true;
This will give you an accurate scale line for the current map viewport.
Regards,
Andreas.
On Apr 28, 2010, at 13:33 , Jan wrote:
> Hi all,
> It seems that in lon/lat projections (e.g. EPSG 4326) the scale line is right only for the Equator (0 lat).
> If you look at the map, e.g.: http://dev.openlayers.org/addins/scalebar/trunk/examples/scalebar.html the scaleline stays constant even if you pan map from N to S. It seems that Poland for example has a width of 1000 km (W-E), while in fact it has approx. 600 km. This is just wrong and for "spatially-unaware" users it will give wrong information.
> AFAIK scale bar's width can be adjusted using:
> OpenLayers.INCHES_PER_UNIT["degrees"] = x;
> where x can be calculated using the length of a given parallel (in inches) divided by 360 degrees. The default inch per unit value is 4374754.
> 4374754 * 360 degrees = 1574911440 inches = 40000 km (the length of the Equator).
> It would be nice to implement a default functionality in OL for automatic adjustments of INCHES_PER_UNIT value based e.g. on the latitude of a map center (for example using moveend or zoomend map events). In this way, the scale bar would be always correct at least in the center of the map. If you create a map for higher latitudes it is crucial. The wrong scale line I would call even a bug (imagine using this scaleline in northern Canada or Norway).
> By the way, it seems that Google Maps uses this method to correct the scale line (check http://maps.google.com, pan the map in N/S direction and see how the scale line adjusts without changing the scale of the map).
> Best regards to all OL users,
> Jan
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
