[OpenLayers-Users] unselect did not work
Sarah Schuessler
sarah_flip at yahoo.de
Wed Apr 28 10:24:39 EDT 2010
Hi Arnd,
thanks for your explanation about styleMap and wms-wfs layer for select control. I thought I could use that with original wfs layer instead of having a wfs.fromwmslayer.
I solved my issue with adding a new default and select Style to my wfs layer and remove lines with selectLayer.addFeatures and selectLayer. removeFeatures (so that I can see my wfs styles and not selectlayer select style).
Thanks for your time and help!
best regards
Sarah
Hi Sarah,
the example shows how to retrieve features from a wms
layer. But you have a vector layer (wfs layer). So you can link the
SelectFeatureControl to that layer.
ctrlSelectFeatureOptions = {
clickout: true, toggle: true, multiple: false, hover: false, toggleKey:
"ctrlKey", multipleKey: "none", box: false };
ctrlSelectFeature = new
OpenLayers.Control.SelectFeature(layerWFS,
ctrlSelectFeatureOptions);
//optional
ctrlSelectFeature.onSelect = function (ft) {
ctrlSelectFeature.onUnselect = function (ft) { };
ctrlSelectFeature.activate();
If you
now click on a feature from your wfs it will be selected. If you do not add
a own styleMap to your wfs layer, the default styleMap is used to display the
features for the different modes (unselected, selected or
temporarily).
If you want use your own
styleMap, you have to declare the styles for the different modes (at last
'default' for unselected features and 'select' for selected features) to see
that you have select a feature.
Arnd
Von: Sarah Schuessler
[mailto:sarah_flip at yahoo.de]
Gesendet: Dienstag, 27. April 2010
09:57
An: Arnd Wippermann
Cc: users at openlayers.org
Betreff: AW: [OpenLayers-Users] unselect did not
work
Hi Arnd,
thanks for your answer!
Please read below.
i'm not sure, why you need a layer for your selected
feature. Why not use the selectFeatureControl on the wfs
layer.
I use my
Control.SelectFeature with my wfs layer(wfs2)- or don`t I use the event right?
(event.register instead of events.on). I get along with this example: http://dev.openlayers.org/releases/OpenLayers-2.9/examples/getfeature-wfs.html to get back a visual selecting for the user and get back some information about
the selected feature.
About your question.
The problem is the feature object. You add not a new
feature to a new layer. Instead it seems, that you move the selected
feature from the wfs layer to the new layer. That means
wfs.event.on("unselected") cann't work, because your selectFeatureControl works
only for the wfs layer.
Yes I thought
something like that, but could not manage to solve this. Thanks for your
example!
Use a
clone of the feature and remove the only feature on your select
layer.
layerWFS.events.on({'featureselected':
function(feature){
selectLayer.addFeatures([feature.feature.clone()]);
//selectLayer.addFeatures([feature.feature]);
alert(this.selectedFeatures.length);
'featureunselected':
function(feature){
selectLayer.removeFeatures([selectLayer.features[0]]);
//selectLayer.removeFeatures([feature.feature]);
alert(this.selectedFeatures.length + " -
unselected");
A bit confusing is also the style you add as default
style to the select layer. It looks like you select a feature on the wfs layer,
but it's really the not selected feature on the select
layer.
So I have to register a
select style to my wfs layer and cancel select layer, am I right?
best
regards
Sarah
Arnd
Von: users-bounces at openlayers.org
[mailto:users-bounces at openlayers.org] Im Auftrag von Sarah
Schuessler
Gesendet: Montag, 26. April 2010 10:28
An: users at openlayers.org
Betreff: [OpenLayers-Users] unselect did not
work
Hi list,
I try to use Control.SelectFeature but I can`t unselect
(selection layer does not get removed). Here is my code:
var selectFeature =
new OpenLayers.Control.SelectFeature(wfs2, {clickout: true, multiple: false,
hover: false, toggle:false, toggleKey: "shiftKey", box: true, multipleKey:
"ctrlKey"});
var wfs2 = new OpenLayers.Layer.Vector("WFS_Waldschutz",
{ styleMap: styleMap,
strategies: [new
OpenLayers.Strategy.Fixed()],
protocol: new
OpenLayers.Protocol.WFS({
url: "http://myserver:81/geoserver/wfs?service=wfs",
featureNS: "http://mycomp.org",
featureType: "mylayer",
geometryName: "SHAPE",
srsName: "EPSG:4326",
version: "1.1.0"
projection: new OpenLayers.Projection("EPSG:4326")
wfs2.events.on({'featureselected': function(feature){
select.addFeatures([feature.feature]);
'featureunselected': function(feature){
select.removeFeatures([feature.feature]);
alert("unselected");
var select = new
OpenLayers.Layer.Vector("Selection", {
styleMap: new
OpenLayers.Style(OpenLayers.Feature.Vector.style["select"]),
displayInLayerSwitcher: true, visibility: true});
featureselected works
(at firebug I can see that my app does not get to this break point). What`s
wrong?
Thank you for any hints.
best
regards
Sarah
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100428/cf3a3c3e/attachment.html
