[OpenLayers-Users] A problem about overlayers
geekjack
geekjack at 163.com
Mon Aug 2 22:23:13 EDT 2010
I have got 2 layer groups(group A and B):
The Group A(the overlayer) can match to the Google Sattelite Map(the
Baselayer) perfectly,but when I change the Group B as the overlayers to the
Google Sattelite Map,it just work like that:
http://geekjack.hostesr.com/bate.png (The blue surface and the yellow line
are parts of Group B) .What I want to say is how can I align the Group B(the
overlayer) to the Google Sattelite Map(the Baselayer) to Eliminate the bias
and make it work well.
Part of my codes:
function init(){
var options = {
projection: new OpenLayers.Projection("EPSG:900913"),
displayProjection: new OpenLayers.Projection("EPSG:4326"),
units: "m",
maxResolution: 156543.0339,
maxExtent: new OpenLayers.Bounds(-20037508.34, -20037508.34,
20037508.34, 20037508.34)
map = new OpenLayers.Map('map', options);
var gmap = new OpenLayers.Layer.Google(
"Google Sattelite",
{type: G_SATELLITE_MAP, 'sphericalMercator': true}
var test = new OpenLayers.Layer.WMS(
"TOPP GroupB",
"http://localhost:8080/geoserver/wms?",
layers: 'Group_B',
styles: '',
srs: 'EPSG:4326',
format: 'image/png',
tiled: 'true',
// tilesOrigin : "-60,-28",
transparent:false
'opacity': 0.2, 'isBaseLayer': true, 'wrapDateLine': true
map.addLayers([gmap,test]);
By the way,i want to know:Does the "tilesorigin" work right in geoserver
2.0.2,it seems no changes when i use it in geoserver 2.0 bu it works in
geoserver 1.7.5.(my English is pool ,maybe i cannot discribe the problem
clearly,but i really need your help),thank you all!
View this message in context: http://osgeo-org.1803224.n2.nabble.com/A-problem-about-overlayers-tp5366694p5366694.html
