[OpenLayers-Users] IE 7 doesn't show my "fluid" map
Nathan Gerber
ngerber999 at gmail.com
Wed Aug 4 13:58:16 EDT 2010
BY manually I meant to say pixel values.
Nathan Gerber
On Wed, Aug 4, 2010 at 1:57 PM, Nathan Gerber <ngerber999 at gmail.com> wrote:
> Not a fix, but rather a work around. Try setting a height and width to your
> div manually. It is likely to break your absolute positioning unless you
> setup a helper JavaScript function to detect what the width and height
> should actually be.
> Nathan Gerber
> On Wed, Aug 4, 2010 at 11:40 AM, Franz Buchinger <fbuchinger at gmail.com>wrote:
>> Hi,
>> I want my openlayers map to fill the whole browser window, it should only
>> leave 200px left and 150 px top offset for UI Elements.
>> Here is my css for the map div:
>> .fluid-map {
>> position: absolute;
>> left: 200px;
>> right: 0px;
>> margin: 0px;
>> top: 150px;
>> bottom: 0px;
>> width: auto;
>> height: auto;
>> border: 1px solid black;
>> When I'm testing my map in IE8, it works fine. But in IE7 mode the map
>> doesn't show up at all, although the div renders correctly. I also don't get
>> any Javascript errors.
>> The innerHTML of my map div contains OpenLayers markup.
>> Any hints?
>> Franz
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100804/c6c12c7f/attachment.html
