[OpenLayers-Users] OpenLayers.Filter.Comparison.LIKE and singleChar
Eric Lemoine eric.lemoine at camptocamp.com
Thu Aug 5 11:31:34 EDT 2010
On Thu, Aug 5, 2010 at 2:28 PM, Arnd Wippermann <arnd.wippermann at web.de> wrote:
> Hi Eric,
> thanks for the reply and the hint. It's a more complex situation.
> It's not a problem with the filter, but with OpenLayers.Format.SLD().read:
> I create a SLD and apply it to a vector layer
> var formatSLD = new OpenLayers.Format.SLD();
> var sld       = formatSLD.read(theSLD_BODY);
> It works perfect, but only the LIKE-filter with "." works not.
> The filterpart from theSLD_BODY for this case looks like
> <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
> <ogc:PropertyIsLike wildCard="*" singleChar="." escape="!">
> <ogc:PropertyName>indice</ogc:PropertyName>
> <ogc:Literal>.2</ogc:Literal>
> </ogc:PropertyIsLike>
> </ogc:Filter>
> The ".2" enters the function OpenLayers.Filter.Comparison.value2regex
> as 0.2 as number (typeof this.value -> number ?!)
> and causes the error "this.value.replace is not a function".
> if I overwrite the function by adding this.value=this.value.toString(), then
> the error vanishes, but the applied rule to the vector layer doesn't result
> in a correct style.
> Appling the same SLD to the WMS layer, shows the correct style. It seems,
> the SLD is correct.
> I remember a case with labels like 02.09, that change to 2.09. Perhaps the
> same issue.
> If you have any hint, where to further look?
Does the attached patch solve the problem?
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100805/8ebf4d3a/patch.obj
