[OpenLayers-Users] mergeNewParams + Legend
Sascha Müller
olaiya at arcor.de
Fri Aug 6 06:23:12 EDT 2010
Do I understand it right, for every layer (WMS) I create, I have to
give the WMS layer a StyleMap with a "default" render intent? Because I
use a VectorLegend?
I have in my App, depending on the customer, a different number of
layers. This sounds like a lot of work for me.
Or I have to create a VectorLegend specially for the layer with the
large SLD?
>> This will tell VectorLegend that it supports all layers that have a
styleMap. >> Does it mean, that the Legend accept ONLY layer that have a
styleMap or accept ALSO layer that have a styleMap?
Another approaches:
- If I change from SLD_BODY to SLD (with the URL of the SLD) in
mergeNewParams(), prevents this a too long URI?
- Is there a way to use 'POST' with GetLegendGraphic?
regards,
Sascha
> Hi,
> I am pretty sure that the request URI is too long. What you could do is reconfigure the legend type selection sequence, so a VectorLegend rather than a WMSLegend is created. A prerequisite is this non-API hack though:
> GeoExt.VectorLegend.supports = function(layerRecord) {
> return layerRecord.get("layer").styleMap;
> This will tell VectorLegend that it supports all layers that have a styleMap.
> Now you can go ahead and create your legendPanel like this:
> var legendPanel = new GeoExt.LegendPanel({
> preferredTypes: ["gx_vectorlegend"]
> Finally, when creating your WMS layer with the SLD_BODY (and before you do mergeNewParams), you have to give the WMS layer a StyleMap with a "default" render intent, which you have to give the style object of your SLD.
> Regards,
> Andreas.
> On Aug 5, 2010, at 17:45 , Sascha Müller wrote:
>> Hi,
>> I tried this SLD with only two instead of five rules. It works.
>> Could it be, that the request 'GetLegendGraphic' is too long with the
>> SLD inside?
>> Like mergeNewParams() without 'Post' in 'OpenLayers.Layer.WMS'.
>> Is there a way to implement it?
>> Or is this more a GeoServer thing?
>> Sascha
>>> Hi,
>>> I use:
>>> GeoExt: trunk (Revision: 2257)
>>> OpenLayers: 2.9
>>> GeoExt: 3.2.1
>>> GeoServer: 1.7.7
>>> I use mergeNewParams() to change the Style of a layer. This approach
>>> works except for one layer.
>>> This layer contains five rules with filter. The map changes after
>>> mergeNewParams(), the legend not.
>>> The layername is still there, the images of the five rules are gone.
>>> If I use this SLD (see below) for the layer with the GeoServer from
>>> start, the layer appears in map and legend. only after
>>> mergenewParams() the layer appears not in the legend.
>>> The layer uses this: var addlayer = new OpenLayers.Layer.WMS.Post()
>>> SLD
>>> <?xml version="1.0" encoding="UTF-8"?>
>>> <sld:StyledLayerDescriptor xmlns="http://www.opengis.net/sld"
>>> xmlns:sld="http://www.opengis.net/sld"
>>> xmlns:ogc="http://www.opengis.net/ogc"
>>> xmlns:gml="http://www.opengis.net/gml" version="1.0.0">
>>> <sld:NamedLayer>
>>> <Name>WL:UBahn</Name>
>>> <sld:UserStyle>
>>> <sld:Name>Default Styler</sld:Name>
>>> <sld:Title/>
>>> <sld:FeatureTypeStyle>
>>> <sld:Name>name</sld:Name>
>>> <sld:FeatureTypeName>Feature</sld:FeatureTypeName>
>>> <sld:SemanticTypeIdentifier>generic:geometry</sld:SemanticTypeIdentifier>
>>> <sld:SemanticTypeIdentifier>colorbrewer:unique:oranges</sld:SemanticTypeIdentifier>
>>> <sld:Rule>
>>> <sld:MinScaleDenominator>0</sld:MinScaleDenominator>
>>> <sld:MaxScaleDenominator>100000000</sld:MaxScaleDenominator>
>>> <sld:Name>rule01</sld:Name>
>>> <sld:Title>U1</sld:Title>
>>> <Filter>
>>> <PropertyIsEqualTo>
>>> <PropertyName>LINIE</PropertyName>
>>> <Literal>U1</Literal>
>>> </PropertyIsEqualTo>
>>> </Filter>
>>> <sld:LineSymbolizer>
>>> <sld:Stroke>
>>> <sld:CssParameter name="stroke">
>>> <Literal>#FEEDDE</Literal>
>>> </sld:CssParameter>
>>> <sld:CssParameter name="stroke-linecap">
>>> <Literal>butt</Literal>
>>> </sld:CssParameter>
>>> <sld:CssParameter name="stroke-linejoin">
>>> <Literal>miter</Literal>
>>> </sld:CssParameter>
>>> <sld:CssParameter name="stroke-opacity">1</sld:CssParameter>
>>> <sld:CssParameter name="stroke-width">3</sld:CssParameter>
>>> <sld:CssParameter name="stroke-dashoffset">
>>> <Literal>0</Literal>
>>> </sld:CssParameter>
>>> </sld:Stroke>
>>> </sld:LineSymbolizer>
>>> </sld:Rule>
>>> <!-- The other RULSs looks the same like the one above -->
>>> </sld:FeatureTypeStyle>
>>> </sld:UserStyle>
>>> </sld:NamedLayer>
>>> </sld:StyledLayerDescriptor>
>>> Is there something wrong with the SLD? Do I have something to consider
>>> if I use mergeNewParams(), or something with the Legend?
>>> Thanks
>>> Sascha
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Users mailing list
