[OpenLayers-Users] Click propagation problem
fooquency fooquency at gmail.com
Sun Aug 8 11:56:30 EDT 2010
> I wonder if someone could help me out with some pointers or a code
solution
> with this OpenLayers problem I've run into. I've been going round for
hours
> trying to work out what's wrong, and I've not come across an obvious
> solution in the documentation. The working example is
> at http://bit.ly/dcutnD
> What I'm trying to achive is:
> 1) Click on an icon
> 2) The popup comes up
> 3) Click 'Choose this point'. The point will be set as the start location
> and the popup balloon will disappear.
> 4) Now if you click on another icon, the same thing should happen. BUT
> instead, the popup briefly appears, a red icon is set (meaning 'finish')
and
> the popup disappears.
> I thought this might be something to do with stopping click propagation,
> which I see can be done using OpenLayers.Handler.Feature stopClick, or
> presumably stopping an event passing through. But I couldn't work out how
to
> attach those to the SelectFeature. And anyway:
> I don't think it's that because the first of the two clicks works exactly
as
> expected without me having to do anything special coding-wise. Therefore
I'm
> wondering if there is some implicit layer re-selection/activation going
on,
> or something that changes the state, which somehow I have to reset.
> The two key files are photomap.js and itinerary.js.
> Also there is a second issue, whereby the green/red markers appear under
the
> main feature icons. I am, however, setting the zIndex and zIndexing, but
to
> no effect - in the Chrome js inspector, both icon types get z-index=auto
for
> the computed style. Again, any pointers would be helpful. (NB I cannot
> trivially change the code order so that the feature layers are loaded in
the
> other order.)
> Any help would be gratefully received!
> Martin
On 3 August 2010 10:15, Pierre wrote:
> I suspect something strange happens in the onFeatureUnselect method.
> I added some breakpoints using firebug and things went well which may
> demonstrate that the onFeatureSelect and onFeatureUnselect call has an
> impact.
> I think you're hopping that they are called in a specific order which
> may be wrong.
> I cannot easily check this but I would add console.log statements to
> verify that removePopup and addPopup calls are correctly called with
> the correct arguments, that CS.popup is not destroyed just after being
> created.
> What I would first suggest is listening to "featureselected" and
> "featureunselected" events instead of onFeatureSelect and
> onFeatureUnselect callbacks.
> This shouldn't radically change things. This is a more modern though.
Pierre, thank you very much for your reply. I've migrated the code to using
those event listeners rather than callbacks. (This hasn't fixed the problem
but at least it is a more modern way.) I also believe the popup calls are
being passed the correct values.
A colleague and I have spent many further hours on this, and we still can't
resolve this. Can anyone provide any further suggestions or a solution? -
We're tearing our hair out on this!
By way of reminder the problem is:
On first click of an icon, the popup comes up fine, and clicking the box
within it then dismisses the popup and sets the green marker.
Clicking on a second icon then results in the marker being selected and the
popup disappearing.
The itinerary.js file does explicitly specify that the popup should
disappear.
So I *think* what is happening on that second icon scenario is:
1) User clicks on the marker
2) The popup is created
3) The click-through propagates to the itinerary marker layer
4) The itinerary.requestNearestPoint method is called, which firstly
destroys the popup, before the user has had a chance to do anything with it.
My hunch is that either:
a) The phase where the red itinerary marker is being placed somehow changes
the layer status, whatever that is. (After all, this all works correctly for
the first icon.) Or:
b) Somehow we have to stop click propagation.
Neither of us are experts at Javascript, and so any help would be very
highly appreciated.
Martin
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100808/2e0d8dd8/attachment.html
