[OpenLayers-Users] mergeNewParams + Legend [SOLVED]
Sascha Müller
olaiya at arcor.de
Mon Aug 9 05:07:53 EDT 2010
The problem had something to do with the GeoServer. To be exact with the
Jetty-Server.
The SLD seems to large for the HeaderBufferSize of the Jetty. With:
<Configure id="Server" class="org.mortbay.jetty.Server">
<Call name="addConnector">
<Arg>
<New class="org.mortbay.jetty.nio.SelectChannelConnector">
<Set name="port"><SystemProperty name="jetty.port" default="8080"/></Set>
<Set name='headerBufferSize'>8192</Set>
</New>
</Arg>
</Call>
</Configure> in the Jetty.xml
The default Value for the headerBufferSize is 4096.
you can increase the HeaderBufferSize.
After this, the Legend works as it should be.
regards,
Sascha
> Hi,
> I see you don't use SLD_BODY any more. So you don't need the whole workaround, and also don't need Layer.WMS.POST. This is good - using SLD instead of SLD_BODY is the preferred option.
> Regards,
> Andreas.
> On Aug 6, 2010, at 16:22 , Sascha Müller wrote:
>> Hi,
>> Ok, I've got it a little bit.
>> 1) I changed in VectorLegend.js
>> GeoExt.VectorLegend.supports = function(layerRecord) {
>> - return layerRecord.get("layer") instanceof OpenLayers.Layer.Vector;
>> + return layerRecord.get("layer").styleMap;
>> 2) I add
>> "preferredTypes: ["gx_vectorlegend"]" to my LegendPanel.
>> 3) I load a WMS-Layer with a SLD_Body:
>> var ub = new OpenLayers.Layer.WMS.Post("U-Bahn Test",
>> "http://localhost:8081/geoserver/wms/",
>> layers: "WL:UBahn",
>> transparent: true,
>> format: 'image/jpeg',
>> sld :
>> "http://localhost:8081/geoserver/styles/myStyle.sld"
>> isBaseLayer: false
>> map.addLayer(ub);
>> 4) But, how do I give the WMS layer a styleMap?
>> var myStyles = new OpenLayers.StyleMap({
>> "default": new OpenLayers.Style({
>> fillColor: "#ffcc66",
>> strokeColor: "#ff9933",
>> strokeWidth: 2,
>> graphicZIndex: 1
>> 4) Do mergeNewParams()
>> Maybe this is an own thread:
>> After this works, is there a way, to get the properties out of the sld
>> and wrire it in the styleMap? similiar to this thread
>> http://osgeo-org.1803224.n2.nabble.com/StyleMap-and-dynamic-loaded-styles-td4961340.html#a4961340
>> The difference is, I got a XML (SLD) back. If not, I have to parse the
>> whole SLd and get all the properties and mut them into the styleMap.
>> regards,
>> Sascha
>>> Hi,
>>> On Aug 6, 2010, at 12:23 , Sascha Müller wrote:
>>>> Do I understand it right, for every layer (WMS) I create, I have to
>>>> give the WMS layer a StyleMap with a "default" render intent? Because I
>>>> use a VectorLegend?
>>> No. The VectorLegend will only be used *if* the WMS layer has a StyleMap. It will still use WMSLegend for other layers
>>>> I have in my App, depending on the customer, a different number of
>>>> layers. This sounds like a lot of work for me.
>>>> Or I have to create a VectorLegend specially for the layer with the
>>>> large SLD?
>>> Yes, just for that layer. Only WMS layers that have a styleMap property will get a VectorLegend if you follow my suggestion.
>>> Regards,
>>> Andreas.
>>>>>> This will tell VectorLegend that it supports all layers that have a
>>>> styleMap.>> Does it mean, that the Legend accept ONLY layer that have a
>>>> styleMap or accept ALSO layer that have a styleMap?
>>>> Another approaches:
>>>> - If I change from SLD_BODY to SLD (with the URL of the SLD) in
>>>> mergeNewParams(), prevents this a too long URI?
>>>> - Is there a way to use 'POST' with GetLegendGraphic?
>>>> regards,
>>>> Sascha
>>>>> Hi,
>>>>> I am pretty sure that the request URI is too long. What you could do is reconfigure the legend type selection sequence, so a VectorLegend rather than a WMSLegend is created. A prerequisite is this non-API hack though:
>>>>> This will tell VectorLegend that it supports all layers that have a styleMap.
>>>>> Now you can go ahead and create your legendPanel like this:
>>>>> var legendPanel = new GeoExt.LegendPanel({
>>>>> Finally, when creating your WMS layer with the SLD_BODY (and before you do mergeNewParams), you have to give the WMS layer a StyleMap with a "default" render intent, which you have to give the style object of your SLD.
>>>>> Regards,
>>>>> Andreas.
>>>>> On Aug 5, 2010, at 17:45 , Sascha Müller wrote:
>>>>>> Hi,
>>>>>> I tried this SLD with only two instead of five rules. It works.
>>>>>> Could it be, that the request 'GetLegendGraphic' is too long with the
>>>>>> SLD inside?
>>>>>> Like mergeNewParams() without 'Post' in 'OpenLayers.Layer.WMS'.
>>>>>> Is there a way to implement it?
>>>>>> Or is this more a GeoServer thing?
>>>>>> Sascha
>>>>>>> Hi,
>>>>>>> I use:
>>>>>>> GeoExt: trunk (Revision: 2257)
>>>>>>> OpenLayers: 2.9
>>>>>>> GeoExt: 3.2.1
>>>>>>> GeoServer: 1.7.7
>>>>>>> I use mergeNewParams() to change the Style of a layer. This approach
>>>>>>> works except for one layer.
>>>>>>> This layer contains five rules with filter. The map changes after
>>>>>>> mergeNewParams(), the legend not.
>>>>>>> The layername is still there, the images of the five rules are gone.
>>>>>>> If I use this SLD (see below) for the layer with the GeoServer from
>>>>>>> start, the layer appears in map and legend. only after
>>>>>>> mergenewParams() the layer appears not in the legend.
>>>>>>> The layer uses this: var addlayer = new OpenLayers.Layer.WMS.Post()
>>>>>>> SLD
>>>>>>> <?xml version="1.0" encoding="UTF-8"?>
>>>>>>> <sld:StyledLayerDescriptor xmlns="http://www.opengis.net/sld"
>>>>>>> xmlns:sld="http://www.opengis.net/sld"
>>>>>>> xmlns:ogc="http://www.opengis.net/ogc"
>>>>>>> xmlns:gml="http://www.opengis.net/gml" version="1.0.0">
>>>>>>> <sld:NamedLayer>
>>>>>>> <Name>WL:UBahn</Name>
>>>>>>> <sld:UserStyle>
>>>>>>> <sld:Name>Default Styler</sld:Name>
>>>>>>> <sld:Title/>
>>>>>>> <sld:FeatureTypeStyle>
>>>>>>> <sld:Name>name</sld:Name>
>>>>>>> <sld:FeatureTypeName>Feature</sld:FeatureTypeName>
>>>>>>> <sld:SemanticTypeIdentifier>generic:geometry</sld:SemanticTypeIdentifier>
>>>>>>> <sld:SemanticTypeIdentifier>colorbrewer:unique:oranges</sld:SemanticTypeIdentifier>
>>>>>>> <sld:Rule>
>>>>>>> <sld:MinScaleDenominator>0</sld:MinScaleDenominator>
>>>>>>> <sld:MaxScaleDenominator>100000000</sld:MaxScaleDenominator>
>>>>>>> <sld:Name>rule01</sld:Name>
>>>>>>> <sld:Title>U1</sld:Title>
>>>>>>> <Filter>
>>>>>>> <PropertyIsEqualTo>
>>>>>>> <PropertyName>LINIE</PropertyName>
>>>>>>> <Literal>U1</Literal>
>>>>>>> </PropertyIsEqualTo>
>>>>>>> </Filter>
>>>>>>> <sld:LineSymbolizer>
>>>>>>> <sld:Stroke>
>>>>>>> <sld:CssParameter name="stroke">
>>>>>>> <Literal>#FEEDDE</Literal>
>>>>>>> </sld:CssParameter>
>>>>>>> <sld:CssParameter name="stroke-linecap">
>>>>>>> <Literal>butt</Literal>
>>>>>>> </sld:CssParameter>
>>>>>>> <sld:CssParameter name="stroke-linejoin">
>>>>>>> <Literal>miter</Literal>
>>>>>>> </sld:CssParameter>
>>>>>>> <sld:CssParameter name="stroke-opacity">1</sld:CssParameter>
>>>>>>> <sld:CssParameter name="stroke-width">3</sld:CssParameter>
>>>>>>> <sld:CssParameter name="stroke-dashoffset">
>>>>>>> <Literal>0</Literal>
>>>>>>> </sld:CssParameter>
>>>>>>> </sld:Stroke>
>>>>>>> </sld:LineSymbolizer>
>>>>>>> </sld:Rule>
>>>>>>> <!-- The other RULSs looks the same like the one above -->
>>>>>>> </sld:FeatureTypeStyle>
>>>>>>> </sld:UserStyle>
>>>>>>> </sld:NamedLayer>
>>>>>>> </sld:StyledLayerDescriptor>
>>>>>>> Is there something wrong with the SLD? Do I have something to consider
>>>>>>> if I use mergeNewParams(), or something with the Legend?
>>>>>>> Thanks
>>>>>>> Sascha
>>>>>>> _______________________________________________
>>>>>>> Users mailing list
>>>>>>> Users at openlayers.org
>>>>>>> http://openlayers.org/mailman/listinfo/users
>>>>>> Users mailing list
>>>> Users mailing list
>> Users mailing list
