[OpenLayers-Users] Using overview map, no layers showing up
Planet)x
andrew.stewart at reddeer.ca
Mon Aug 9 10:35:25 EDT 2010
Not sure if I am doing this correctly, I am trying to experiment with using
an overview map and I just want to set it to be a copy of the layers on my
map already existing. Below is my code but I just get an empty blue overview
map with no layers showing and also it won't move my map around if I click
on it. Any help appreciated whether to define new layers for my overview or
make an exact copy of the existing map, thanks.
<%@ Page Language="VB" AutoEventWireup="false" CodeFile="Default.aspx.vb"
Inherits="_Default" %>
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<title>Redgis - WMS Service</title>
<link rel="stylesheet" href="style.css" type="text/css" />
<style type="text/css">
body {
margin: 0;
#map {
width: 100%;
height: 100%;
#text {
position: absolute;
bottom: 1em;
left: 1em;
width: 512px;
#overview{
display:block;
/* set the div in the bottom right */
position:absolute;
bottom:0;
right:0;
width:350px;
border:1px solid #ddd;
</style>
<!-- (commented out google maps API key, readd if using google maps
layer) <script
src='http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAmxEu3pgjOVMKW70xRnZ1YxR0mfnfRZQjoAkWM97eIDxNT8rs-xT5NYTmYFApu1-LGwQBNRBUweZGdg'
type="text/javascript"></script>-->
<script type="text/javascript"
src="OpenLayers-2.9.1/OpenLayers.js"></script>
<script type="text/javascript">
var map;
function init(){
map = new OpenLayers.Map('map',{
maxExtent: new OpenLayers.Bounds(-20037508.34,
-20037508.34, 20037508.34, 20037508.34),
maxResolution: 156543.0399,
numZoomLevels: 20,
units: 'm',
projection: new OpenLayers.Projection("EPSG:900913"),
displayProjection: new
OpenLayers.Projection("EPSG:4326")
//Commented out adding google maps as a layer, readd if using google as
base layer
//var gmap = new OpenLayers.Layer.Google(
//"Google Streets", // the default
//{numZoomLevels: 20
//, sphericalMercator: true
//Bridge
var wmsBridge = new OpenLayers.Layer.WMS("Bridge",
"http://ITS701X5J1/RedWMS/Request.aspx",
layers: ['Bridge'],
format: 'image/png',
VERSION: "1.1.1",
transparent: true
{ isBaseLayer: false
, singleTile: true
wmsBridge.setOpacity(0.8);
//Rural_Highway
var wmsRural_Highway = new OpenLayers.Layer.WMS("Rural Highway",
layers: ['Rural_Highway'],
VERSION: "1.1.1",
transparent: true
, singleTile: true
wmsRural_Highway.setOpacity(0.8);
//Highway
var wmsHighway = new OpenLayers.Layer.WMS("Highway",
layers: ['Highway'],
VERSION: "1.1.1",
transparent: true
, singleTile: true
wmsHighway.setOpacity(0.8);
//Arterial
var wmsArterial = new OpenLayers.Layer.WMS("Arterial",
layers: ['Arterial'],
VERSION: "1.1.1",
transparent: true
, singleTile: true
wmsArterial.setOpacity(0.8);
//City_Boundary
var wmsCity_Boundary = new OpenLayers.Layer.WMS("City Boundary",
layers: ['City_Boundary'],
VERSION: "1.1.1",
transparent: true
, singleTile: true
wmsCity_Boundary.setOpacity(0.8);
//Hydrology
var wmsHydrology = new OpenLayers.Layer.WMS("Hydrology",
layers: ['Hydrology'],
VERSION: "1.1.1",
transparent: true
, singleTile: true
wmsHydrology.setOpacity(0.8);
//Neighbourhood Area (Clear)
var wmsNeighbourhood_Clear = new
OpenLayers.Layer.WMS("Neighbourhood Area (Clear)",
layers: ['Neighbourhood_Area__Clear_'],
VERSION: "1.1.1",
transparent: true
, singleTile: true
wmsNeighbourhood_Clear.setOpacity(0.8);
//Neighbourhood Boundary
var wmsNeighbourhood_Boundary = new
OpenLayers.Layer.WMS("Neighbourhood Boundary",
layers: ['Neighbourhood_Boundary'],
VERSION: "1.1.1",
transparent: true
, singleTile: true
wmsNeighbourhood_Boundary.setOpacity(0.8);
//Major Parks
var wmsMajor_Parks = new OpenLayers.Layer.WMS("Major Parks",
layers: ['Major_Parks'],
VERSION: "1.1.1",
transparent: true
, singleTile: true
wmsMajor_Parks.setOpacity(0.8);
//Neighbourhood Parks
var wmsNeighbourhood_Parks = new
OpenLayers.Layer.WMS("Neighbourhood Parks",
layers: ['Neighbourhood_Parks'],
VERSION: "1.1.1",
transparent: true
, singleTile: true
//Recreation Sites
var wmsRecreation_Sites= new OpenLayers.Layer.WMS("Recreation
Sites", "http://ITS701X5J1/RedWMS/Request.aspx",
layers: ['Recreation_Sites'],
VERSION: "1.1.1",
transparent: true
, singleTile: true
wmsRecreation_Sites.setOpacity(0.8);
//School Sites
var wmsSchool_Sites= new OpenLayers.Layer.WMS("School Sites",
layers: ['School_Sites'],
VERSION: "1.1.1",
transparent: true
, singleTile: true
wmsSchool_Sites.setOpacity(0.8);
//Linear Parks
var wmsLinear_Parks= new OpenLayers.Layer.WMS("Linear Parks",
layers: ['Linear_Parks'],
VERSION: "1.1.1",
transparent: true
, singleTile: true
wmsLinear_Parks.setOpacity(0.8);
//Section Lines
var wmsSection_Lines= new OpenLayers.Layer.WMS("Section Lines",
layers: ['Section_Lines'],
VERSION: "1.1.1",
transparent: true
{ isBaseLayer: true
, singleTile: true
wmsSection_Lines.setOpacity(0.8);
wmsSection_Lines.displayInLayerSwitcher = false //hides
layer from displaying in layerswitcher control
//Rural Block Line
var wmsRural_Block_Line= new OpenLayers.Layer.WMS("Rural Block
Line", "http://ITS701X5J1/RedWMS/Request.aspx",
layers: ['Rural_Block_Line'],
VERSION: "1.1.1",
transparent: true
, singleTile: true
wmsRural_Block_Line.setOpacity(0.8);
//Rural Lot Line
var wmsRural_Lot_Line= new OpenLayers.Layer.WMS("Rural Lot
layers: ['Rural_Lot_Line'],
VERSION: "1.1.1",
transparent: true
, singleTile: true
wmsRural_Lot_Line.setOpacity(0.8);
//map.addLayers([gmap, wms]);
map.addLayers([wmsBridge, wmsRural_Highway, wmsHighway,
wmsArterial, wmsCity_Boundary, wmsHydrology, wmsNeighbourhood_Clear,
wmsNeighbourhood_Boundary, wmsMajor_Parks, wmsNeighbourhood_Parks,
wmsRecreation_Sites, wmsSchool_Sites, wmsLinear_Parks, wmsSection_Lines,
wmsRural_Block_Line, wmsRural_Lot_Line]);
var startupLat = 52.27210;
var startupLon = -113.80288;
var startupLevel = 11.5;
//var lonLat = new OpenLayers.LonLat(startupLon, startupLat);
startupLat).transform(new OpenLayers.Projection("EPSG:4326"),
map.getProjectionObject());
map.setCenter(lonLat, startupLevel);
// Define Controls
var redgisLegend = new OpenLayers.Control.LayerSwitcher();
var redgisOverview = new OpenLayers.Control.OverviewMap();
var keyboard = new OpenLayers.Control.KeyboardDefaults();
var mousePosition = new OpenLayers.Control.MousePosition();
// add controls to map
map.addControl(redgisLegend);
map.addControl(redgisOverview);
map.addControl(keyboard);
map.addControl(mousePosition);
redgisLegend.maximizeControl();
redgisOverview.maximizeControl();
</script>
</head>
<body onload="init()">
<div id="map"></div>
</body>
</html>
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Using-overview-map-no-layers-showing-up-tp5389216p5389216.html
