[OpenLayers-Users] Markers with dymamically changing appearance
Sveen Atle Frenvik (Geomatikk IKT)
Atle.Frenvik.Sveen at geomatikk.no
Wed Aug 11 05:18:41 EDT 2010
Regarding the first question:
i did something like this in order to create a rectangle of a given
pixel size centered on a coordinate on the map (to make a print tool)..
the relevant code parts are:
first i set up some choices for paper sizes
//the available paper sizes
papers: {
"a4_landscape":{
width: 3507,
height: 2481,
box: "landscape"
"a4_portrait": {
name: "A4 St\345ende",
width: 2481,
height: 3507,
box: "portrait",
selected: true
"a3_landscape":{
name: "A3 Liggende",
width: 4962,
height: 3507,
box: "landscape"
"a3_portrait": {
name: "A3 St\345ende",
width: 3507,
height: 4962,
box: "portrait"
sizes: {
"portrait": {
width: 496,
height: 700
"landscape": {
width: 700,
height: 496
then i start off with setting the paper, which finds the width and
height based on the given paper (this could probably be simplified a
lot, not finished yet), finds the map center and gets the pixel value
for that, and then either creates or moves the polygon
setPaper: function(paper) {
this.paper = paper;
//get the boxSize
this.boxSize = {};
this.boxSize.width = this.sizes[this.papers[this.paper].box].width;
this.boxSize.height =
this.sizes[this.papers[this.paper].box].height;
//find the center pixel for the box
var centerPx = this.map.getPixelFromLonLat(this.map.getCenter());
//create or move the polygon to the center of the map
if (!this.feature) {
this.addPolygon(this.paper, centerPx);
else {
this.lastCenter = this.feature.geometry.getCentroid();
this.movePolygon();
//add the print area polygon
addPolygon: function(paper, centerPx) {
//remove previous feature
this.mylayer.destroyFeatures();
//calculate the extent of the box
var addX = this.boxSize.width / 2;
var addY = this.boxSize.height / 2;
var center = this.map.getLonLatFromPixel(new
OpenLayers.Pixel(centerPx.x,centerPx.y));
var leftBottom = this.map.getLonLatFromPixel(new
OpenLayers.Pixel(centerPx.x-addX, centerPx.y+addY));
var rightTop = this.map.getLonLatFromPixel(new
OpenLayers.Pixel(centerPx.x+addX, centerPx.y-addY));
//create the polygon, the feature and add to the layer
var poly = new OpenLayers.Geometry.Polygon(
new OpenLayers.Geometry.LinearRing([
new OpenLayers.Geometry.Point(leftBottom.lon,
leftBottom.lat),
rightTop.lat),
new OpenLayers.Geometry.Point(rightTop.lon,
rightTop.lat),
leftBottom.lat)
this.feature = new OpenLayers.Feature.Vector(poly);
this.mylayer.addFeatures([this.feature]);
movePolygon: function() {
var pixel = this.map.getPixelFromLonLat(new
OpenLayers.LonLat(this.lastCenter.x, this.lastCenter.y));
var lastPixel = this.map.getPixelFromLonLat(this.map.getCenter());
var res = this.map.getResolution();
this.feature.geometry.move(res * (pixel.x - lastPixel.x),
res * (lastPixel.y - pixel.y));
this.mylayer.drawFeature(this.feature);
and then a listener for zoomend this.map.events.register("zoomend",
this, this.scaleChanged);
which calls:
//scale of map changed
scaleChanged: function() {
to redraw the polygon
hope this helps somewhat
-atle
On 08/11/2010 10:00 AM, Bart van den Eijnden (OSGIS) wrote:
> Hi,
> please always cc the list, since I don't know all the answers and people
> with similar issues can find it in the e-mail archives later on.
> Your first question: I don't know.
> Redrawing can be done using:
> feature.layer.drawFeature(feature);
> http://dev.openlayers.org/docs/files/OpenLayers/Layer/Vector-js.html#OpenLayers.Layer.Vector.drawFeature
> Best regards,
> Bart
>> On Aug 11, 2010, at 0:16 , Bart van den Eijnden (OSGIS) wrote:
>>> please check out:
>>> http://docs.openlayers.org/library/feature_styling.html
>>> Labels can be drawn as well with vector features, see e.g.:
>>> http://openlayers.org/dev/examples/vector-features-with-text.html
>> Thanks.
>> Two more questions:
>> - how do I draw in screen coordinates (I need to draw a polygon starting
>> from a latlong, then draw 2em up and to the right etc), and have it stay
>> the same size on-screen when the user zooms (ie make markers)?
>> - how do I redraw these things? Just erase them and draw new ones, or do I
>> replace their graphics properties?
Atle Frenvik Sveen
Utvikler
Geomatikk IKT AS
tlf: 45 27 86 89
atle.frenvik.sveen at geomatikk.no
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100811/9c728ad7/attachment.html
