[OpenLayers-Users] GeoTIFF display
Jon Britton
jonbritton3 at googlemail.com
Thu Aug 12 06:36:41 EDT 2010
If you want to use Java to submit your GeoTiff to GeoServer via REST then I
might have some code for you to use. Just let me know!
Jon
On 12 August 2010 10:38, Mickael BEAUFILS <mickael.beaufils at acatus.fr>wrote:
> Hi Jon, Hi Andreas,
> Thanks for your answer.
> Well I never used the GeoServer REST API, but according to you it seems to
> be the solution.
> I will have a close look to it and try this.
> Regards,
> Mickael Beaufils
> *De :* mankillseverything at googlemail.com [mailto:
> mankillseverything at googlemail.com] *De la part de* Jon Britton
> *Envoyé :* jeudi 12 août 2010 11:02
> *À :* Mickael BEAUFILS
> *Objet :* Re: [OpenLayers-Users] GeoTIFF display
> Are you sure you can't use geoserver? I do something similar using the
> geoserver REST API to store my WPS output. I do this all programmatically
> from a Java servlet.
> Jon
> On 12 Aug 2010 08:47, "Mickael BEAUFILS" <mickael.beaufils at acatus.fr>
> wrote:
> > Hi everyone,
> > I am creating some geoTIFF files via a WPS request and I would like to
> > display them in an Openlayers framework.
> > GeoServer enable to do this but not in a direct way (you have to put the
> > files in geoserver data directory, config the access the file in the
> > Geoserver admin page, ...).
> > At this time, is there a solution to directly display a geoTIFF on
> > OpenLayers ?
> > Thanks for your help !
> > Regards,
> > MB
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100812/cbc89cb1/attachment.html
