[OpenLayers-Users] Problem while adding a vector layer
Arnd Wippermann
arnd.wippermann at web.de
Thu Aug 12 08:49:40 EDT 2010
Your maxExtent defines a little area about 1x1 sqm at 0,0 because you use
spericalMercator.
Extent in EPSG:900913
maxExtent:new
OpenLayers.Bounds(9258442.0492536,1996037.9243878,9282932.3372281,2012982.98
40631)
Or transform your coordinates
maxExtent : new
OpenLayers.Bounds(83.170,17.645,83.390,17.790).transform(new
OpenLayers.Projection("EPSG:4326"), new
OpenLayers.Projection(map.projection))
Arnd
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von usha madhuri
Gesendet: Donnerstag, 12. August 2010 12:38
An: users at openlayers.org
Betreff: Re: [OpenLayers-Users] Problem while adding a vector layer
I have used SphericalMercator and my code is as below, function load() { map
= new OpenLayers.Map(document.getElementById("map"));
OpenLayers.ProxyHost="/proxy/?url=";
var options = {
projection: new OpenLayers.Projection("EPSG:900913"),
displayProjection: new OpenLayers.Projection("EPSG:4326"),
units: "m",
numZoomLevels: 18,
maxResolution: 156543.0339,
maxExtent: new
map = new OpenLayers.Map('map', options);
google = new OpenLayers.Layer.Google(
"Google Streets",
{'sphericalMercator': true}
map.addLayer(google);
using this I am not able to pan the map. Please tell me where have I gone
wrong.
Regards,
Madhuri
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/Problem-while-adding-a-vector-layer-t
p4869632p5415604.html
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
