[OpenLayers-Users] How to Disable the spherical? I want to
display a flat map...
andrey
andrey_kong at hotmail.com
Fri Aug 13 11:46:39 EDT 2010
nevermind i found out its other problems...
the problem is when I used offset of click.xy on map to add custom
features... (e.g. a pin graphic which needed to offset to north to display
its pin on the clicked spot)
but this offset will project larger when zoom out ....
I changed to use offsets of image on layer and it fixed the problem.
graphicXOffset graphicYOffset
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-Disable-the-spherical-I-want-to-display-a-flat-map-tp5410459p5420520.html
