[OpenLayers-Users] arcgis server 10
BMcBride
bmcbride at chacompanies.com
Tue Aug 17 09:13:25 EDT 2010
Hi Sarah,
You can test OpenLayers with
http://resources.arcgis.com/content/arcgisserver/10.0/sample-gis-server-and-gis-services
ESRI's sample servers . I did a quick test on the
http://openlayers.org/dev/examples/arcgis93rest.html OpenLayers ArcGIS
Server 9.3 Rest API Example and it appears to work fine with an ArcGIS
Server 10 Map Service
(http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Earthquakes/Since_1970/MapServer/export).
Given the option however, I would most definitely go with a
GeoServer/PostGIS configuration. There is much more documentation and code
samples for this setup and it just seems to work better in general. I use
GeoServer for my key operational layers and bring in ArcGIS Server layers as
basemaps from ESRI, USGS, etc.
BRYAN
Bryan R. McBride, GISP
http://www.bryanmcbride.com bryanmcbride.com
http://geoserving.net/ geoserving.net
View this message in context: http://osgeo-org.1803224.n2.nabble.com/arcgis-server-10-tp5431309p5431998.html
