[OpenLayers-Users] Is it possible to show a subsection (sprite)
of an image as a marker?
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Wed Aug 18 05:24:39 EDT 2010
Hi Matt,
not out of the box unfortunately.
This would either require changes to the current renderers (SVG and VML),
or implementing your own custom renderer. I did something like this a
while ago, see:
http://osgisjs.blogspot.com/2010/06/anchor-renderer.html
Best regards,
Bart
> My application has 100 marker images that I want to display on the Map. I
> don't want to force to user to download 100 images. A technique that has
> worked for other graphic intensive sites, is to send all the markers down
> as
> sprites in a single image (http://www.alistapart.com/articles/sprites),
> and
> use CSS to control which part of the image is shown for every marker.
> Does OpenLayers have support for these sorts of techniques in the Vector
> Layer? If not, is it possible to use custom html as a marker instead of a
> graphic?
> http://osgeo-org.1803224.n2.nabble.com/Is-it-possible-to-show-a-subsection-sprite-of-an-image-as-a-marker-tp5435420p5435420.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Looking for flexible support on OpenLayers or GeoExt? Please check out
http://www.osgis.nl/support.html
OSGIS
bartvde at osgis.nl
