[OpenLayers-Users] Switching between a Google/Bing base layer
to WMS base layer...
Paul james
pauljame at gmail.com
Wed Aug 18 10:00:09 EDT 2010
Yes, My proj.4 has EPSG:900913...
My mapfile:
MAP
PROJECTION
"+init=epsg:4326"
END
WEB
IMAGEPATH '...'
IMAGEURL '...'
METADATA
"wms_title" "WMS Server"
"wms_onlineresource" "..."
"wms_srs" "EPSG:4326 EPSG:900913 EPSG:3857"
"wms_feature_info_mime_type" "text/html"
"labelcache_map_edge_buffer" "-10"
END
END
LAYER
NAME TestBase
METADATA
"wms_srs" "EPSG:900913"
"wms_title" "TestBase"
END
Thanks
Paul
On Wed, Aug 18, 2010 at 10:49 AM, David Fawcett <david.fawcett at gmail.com>wrote:
> Paul,
> What does the rest of your mapfile look like?
> Is there a record for EPSG:900913 in your proj.4 database?
> David.
> On Wed, Aug 18, 2010 at 8:29 AM, Paul james <pauljame at gmail.com> wrote:
> > I tried that setting wms_srs (mapserver):
> > METADATA
> > "wms_title" "Test"
> > END
> > But without success...
> > Any idea?
> > Thanks
> > On Wed, Aug 18, 2010 at 10:02 AM, BMcBride <bmcbride at chacompanies.com>
> > wrote:
> >> Paul james wrote:
> >> > Is it possible to reproject my baselayer in client? How?
> >> I don't believe so. Your baselayer's native projection should be
> >> EPSG:900913. You also may be able to reproject server side by defining
> a
> >> SRS parameter (I know this works with GeoServer).
> >> Bryan R. McBride, GISP
> >> http://www.bryanmcbride.com bryanmcbride.com
> >> http://geoserving.net/ geoserving.net
> >> View this message in context:
> http://osgeo-org.1803224.n2.nabble.com/Switching-between-a-Google-Bing-base-layer-to-WMS-base-layer-tp5431832p5436172.html
> >> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> >> _______________________________________________
> >> Users mailing list
> >> Users at openlayers.org
> >> http://openlayers.org/mailman/listinfo/users
> > Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100818/5b97a95f/attachment.html
