[OpenLayers-Users] LayerSwitcher - Panel show and disable
layerentry - additional
Jan Tappenbeck
osm at tappenbeck.net
Fri Aug 20 07:15:19 EDT 2010
this version show the panel permanent - is it possible to hide again by
the (+) sign ???
regards Jan :-)
Am 20.08.2010 13:13, schrieb Jan Tappenbeck:
> HI !
> thanks for the message - and it work - look at:
> http://www.tappenbeck.net/osm/maps/deu/index_new.php?id=1017
> but can you tell me why firebugs write:
> layer is not defined
> [Break on this error] layer.setVisibility(false);
> regards Jan :-)
> Am 19.08.2010 15:09, schrieb BMcBride:
>> To make the layerswitcher initially visible, you can do something like:
>> map.addControl(new OpenLayers.Control.LayerSwitcher({'ascending':false}));
>> var ls = map.getControlsByClass('OpenLayers.Control.LayerSwitcher')[0];
>> ls.maximizeControl();
>> To set layer visibility, you can do something like:
>> Bryan R. McBride, GISP
>> http://www.bryanmcbride.com bryanmcbride.com
>> http://geoserving.net/ geoserving.net
