[OpenLayers-Users] Why is my WFS layer not showing up?
Gregor at HostGIS gregor at hostgis.com
Mon Aug 23 12:23:51 EDT 2010
> Second:
> When I use your wfs server with EPSG:23031, then the points will display in
> Barcelona. But only for the layer "cloud2". The gml for the layers named by
> numbers are not valid.<ms:4>  seems to be no correct tag.
Correct. I am not using #4 in this demo, only cloud2.
> the point in the snippet you have posted, lies if the projection is right,
> south-east of Mallorca. If you take the projection EPSG:23031, then it
> should be in Barcelona.
Ah, I missed that; the numbers in the 2 SRSs are similar (250k x 5M) and
I didn't notice that
I added the PROJECTION to the LAYER and you're right, the numbers come
out differently. Strange, I thought that layers would inherit the MAP's
projection. I guess not in this case.
This still didn't get the features showing up, and I'm not sure why.
BUT... I just got the email about 20 minutes ago that the project was
cancelled over the weekend -- so never mind. Thanks for the effort,
Arnd! It IS appreciated!
HostGIS, Open Source solutions for the global GIS community
Greg Allensworth - SysAdmin, Programmer, GIS Person, Security
    Network+   Server+   A+   Security+   Linux+
    PHP   PostgreSQL   MySQL   DHTML/JavaScript/AJAX
"No one cares if you can back up — only if you can recover."
