[OpenLayers-Users] FeatureInfo-Popup not returning results
Sven Burbeck
sburbeck at bfs.de
Tue Aug 24 06:36:43 EDT 2010
Hi Marc,
thanks for your hint regarding the vendorParams. It at least solves
part of the problem (passing the URl to the constructor didn't work).
I now produce a request that has the "map" parameter and the request
gets a response from the server (format=html).
However, GeoExt.popup opens but is still blank and doesn't show the html.
Firebug throws an error (just the GET request) although I can take
this request and get a proper response from the server.
any idea?
cheers,
Sven
Quoting "Marc Jansen" <jansen at terrestris.de>:
> Hi Sven,
> The error message you see come from UMN mapserver moaning about the
> missing URL parameter MAP, not the OpenLayers Map.
> Have you tried to pass over an URL to the Constructor of the control
> (this isn't documented in the API, but maybe should be)?
> featureInfo = new OpenLayers.Control.WMSGetFeatureInfo({
> url : 'http://example.com/mapserver?map=/path/to/mapfile.map'
> If the above fails, you could use the non-API-property "vendorParams" (I
> cannot see a reason why this is a hidden option):
> vendorParams: {
> map: '/path/to/mapfile.map'
> If both work, I'd go with the vendorParams, because that is what UMN
> Mapservers MAP url parameter is.
> Untested, hope it helps,
> Marc
> On 24.08.2010 11:00, Sven Burbeck wrote:
>> Hi list,
>> I'm struggling to show GetFeatureInfo results in a GeoExtPopup.
>> I used the sample code for openLayers / GeoExt.popup.
>> That's the code:
>> var featureInfo = new OpenLayers.Control.WMSGetFeatureInfo();
>> featureInfo.events.on({
>> getfeatureinfo: function(e) {
>> new GeoExt.Popup({
>> title: "Info",
>> width: 200,
>> height: 150,
>> autoScroll: true,
>> maximizable: true,
>> map: map,
>> lonlat: map.getLonLatFromPixel(e.xy),
>> html: e.text
>> }).show();
>> map.addControl(featureInfo);
>> featureInfo.activate();
>> My WMS comes from MapServer (and FeatureInfo apparently works on the
>> selected layers).
>> When checking the request (copied from firebug) directly in the browser
>> I get the following error message:
>> 'loadMap(): Web application error. CGI variable "map" is not set.'
>> And that's actually true. When adding the "map" parameter manually
>> everything works well.
>> However, I thought the requests "map" and "layers" parameter were given
>> by "map:map".
>> Maybe I simply missed something but currently I don't know what.
>> cheerrs,
>> Sven
> Karten im (Inter|Intra)net?
> OpenLayers - Webentwicklung mit dynamischen Karten und Geodaten
> von M. Jansen und T. Adams, OpenSourcePress, München.
> ISBN: 978-3-937514-92-5
> URL: http://openlayers-buch.de
> Dipl.-Geogr. Marc Jansen
> - Anwendungsentwickler -
> terrestris GmbH& Co. KG
> Irmintrudisstraße 17
> 53111 Bonn
> Tel: ++49 (0)228 / 96 28 99 -53
> Fax: ++49 (0)228 / 96 28 99 -57
> Email: jansen at terrestris.de
> Web: http://www.terrestris.de
> Amtsgericht Bonn, HRA 6835
> Komplementärin: terrestris Verwaltungsgesellschaft mbH
> vertreten durch: Hinrich Paulsen, Till Adams
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
