[OpenLayers-Users] WMSGetFeatureInfo eventListener resolving
dependencies
Eric Lemoine
eric.lemoine at camptocamp.com
Wed Aug 25 00:55:00 EDT 2010
On Wednesday, August 25, 2010, Sige <sigenz at yahoo.co.nz> wrote:
> Hi All,
> I have a WMS layer with a popup control for feature info:
> var featureInfo = new OpenLayers.Control.WMSGetFeatureInfo(
> { url: "http://localhost/geoserver/wms",
> hover:false,
> maxFeatures:5,
> layers: [wmsLayer],
> queryVisible: true,
> eventListeners: {
> getfeatureinfo: function(event) {
> if(event.text){
> //add openlayers popup window
> map.addPopup(new OpenLayers.Popup.FramedCloud(
> "geoserver_info",
> map.getLonLatFromPixel(event.xy),
> null,
> event.text,
> null,
> true
> { radius: 50}
> map.addControl(featureInfo);
> featureInfo.activate();
> Which works fine with the full build of Openlayers.js. However, it stops
> working when using a custom lite build of Openlayers, the response from
> feature info request is there but the popup window dosn't show up.
> Obviously I have missed some classes in building Openlayers.js but I could
> not figure out whats needed as there is no error message on firebug. My
> build config is as follows:
> [first]
> OpenLayers/SingleFile.js
> OpenLayers.js
> OpenLayers/BaseTypes.js
> OpenLayers/BaseTypes/Class.js
> OpenLayers/Util.js
> Rico/Corner.js
> OpenLayers/Console.js
> [last]
> [include]
> OpenLayers/Bounds.js
> OpenLayers/Map.js
> OpenLayers/Layer/WMS.js
> OpenLayers/Ajax.js
> OpenLayers/Events.js
> OpenLayers/Layer.js
> OpenLayers/Layer/Grid.js
> OpenLayers/Layer/HTTPRequest.js
> OpenLayers/Layer/WMS/Untiled.js
> OpenLayers/Tile.js
> OpenLayers/Tile/Image.js
> OpenLayers/Popup.js
> OpenLayers/Popup/Anchored.js
> OpenLayers/Popup/Framed.js
> OpenLayers/Popup/FramedCloud.js
> OpenLayers/Control.js
> OpenLayers/Control/Navigation.js
> OpenLayers/Control/MousePosition.js
> OpenLayers/Control/LayerSwitcher.js
> OpenLayers/Control/PanZoom.js
> OpenLayers/Control/ArgParser.js
> OpenLayers/Control/Attribution.js
> OpenLayers/Control/Scale.js
> OpenLayers/Control/WMSGetFeatureInfo.js
> OpenLayers/Format.js
> OpenLayers/Format/XML.js
> OpenLayers/Format/WMSGetFeatureInfo.js
> OpenLayers/Request.js
> OpenLayers/Request/XMLHttpRequest.js
> OpenLayers/Handler.js
> OpenLayers/Handler/Click.js
> OpenLayers/Handler/Hover.js
> Anybody knows the dependencies for the WMSGetFeatureInfo popup and the class
> of the eventListeners ?
you probably need to include OpenLayers/Format/GML.js, but I'm not
sure this is your problem since you aren't seeing errors in the FB
console.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
