[OpenLayers-Users] Problem with LoadingPanel in IE8
Kalyan Kamepalli
kalyan.kamepalli at gmail.com
Wed Aug 25 20:33:40 EDT 2010
I got a very good link to generate gif files with different symbols like
wheel , clock , flower and so on.. Here is the link for you .
http://ajaxload.info/
But, this still remains a problem with IE8.
On Thu, Aug 26, 2010 at 10:31 AM, Kalyan Kamepalli <
kalyan.kamepalli at gmail.com> wrote:
> Bryan,
> I now figured the problem. It's working fine with IE6. Unfortunately, I can
> not test this on Firefox, Chrome or Safari as our development servers don't
> have them installed. However for the last couple of days I have been testing
> this on IE8 and that just didn't work. Surprisingly, it didn't show any
> error messages in development tools of IE. I think some problem with CSS for
> IE8. I just tested this on IE6 and that worked.
> Any one else figured this problem before ? Are there any other problems
> with IE8 ?
> Just got another question here. I changed my image from loading.gif to some
> picture.gif with wheel type image and that did turn up well.But, the problem
> here is, it remained static where as in the case of loading.gif , it showed
> that nice progressive status ( The green bar keep increasing ). How to make
> my wheel like picture get rotating kind of feel ??
> Any suggestions and ideas are greatly appreciated.
> Cheers,
> Kalyan.
> On Wed, Aug 25, 2010 at 10:54 PM, McBride, Bryan <
> BMcBride at chacompanies.com> wrote:
>> Hi Kaylan,
>> What errors are you getting in firebug? You should be able to just
>> reference OpenLayers.js and LoadingPanel.js, add the stylesheet (with a
>> valid path to the loading.gif), and add the control to your map. Did you
>> download the loading.gif image and place it in your theme directory as your
>> code shows? If not, you may be able to change the image path to *
>> http://dev.openlayers.org/addins/loadingPanel/trunk/theme/default/img/loading.gif
>> *. Without a link to your map or a code snippet or firebug error, this
>> is the best I can do to help you troubleshoot…
>> Best of luck!
>> BRYAN
>> *Bryan R. McBride, GISP***
>> GIS Programmer/Analyst
>> *CHA* *~ Imagine What We Can Do For You!***
>> 518.453.3975
>> bmcbride at chacompanies.com
>> www.chacompanies.com
>> *From:* Kalyan Kamepalli [mailto:kalyan.kamepalli at gmail.com]
>> *Sent:* Tuesday, August 24, 2010 7:36 PM
>> *To:* McBride, Bryan
>> *Subject:* Re: [OpenLayers-Users] Define several states of view
>> (Zoom/Area)
>> Hi Bryan,
>> The document says ,
>> *Use subversion to check out the **LoadingPanel*<http://svn.openlayers.org/addins/loadingPanel/trunk/>
>> * addin. *
>> I downloaded LoadingPanel.js
>> *Place the **LoadingPanel.js*<http://trac.openlayers.org/browser/addins/loadingPanel/trunk/lib/OpenLayers/Control/LoadingPanel.js>
>> * file in your **Control*<http://trac.openlayers.org/browser/trunk/openlayers/lib/OpenLayers/Control>
>> * directory (or alternatively, place it elsewhere and add a **<script>**tag to your page that points to it).
>> I placed it directly under openlayers folder but not under
>> control directory. Added a script tag
>> <script src= "LoadingPanel.js"></script>
>> *Use the **build tools* <http://trac.openlayers.org/wiki/Profiles>* to
>> create a single file build (or link to your OpenLayers.js file to run in
>> development mode).*
>> Is it really needed to build a single file. I haven't done this
>> part. What about linking to OpenLayers.js file ? How to
>> link LoadingPanel.js to OpenLayers.js ??
>> *Add a stylesheet to your page to style the LoadingPanel (see examples).
>> Added
>> .olControlLoadingPanel {
>> background-image:url(../theme/default/img/loading.gif);
>> position: relative;
>> width: 195px;
>> height: 11px;
>> background-position:center;
>> background-repeat:no-repeat;
>> display: none;
>> to my style.css
>> *Construct a map and add a LoadingPanel to it*
>> I added something like this to my HTML
>> map
>> .addControl( *new* OpenLayers.Control.LoadingPanel()) ;
>> After all the above, I couldn't make my loading Panel working. Is there
>> something that I am missing ??
>> On Tue, Aug 24, 2010 at 11:10 PM, McBride, Bryan <
>> Hi Kaylan,
>> Everything you need for this should be available here:
>> http://trac.openlayers.org/wiki/Addins/LoadingPanel
>> BRYAN
>> 518.453.3975
>> *Sent:* Tuesday, August 24, 2010 7:41 AM
>> (Zoom/Area)
>> Hello Bryan,
>> I would like to set up a status notifier/ progress bar something like the
>> one you set up in geoexplorer. Is there any chance that you could that piece
>> of code with me or could you give me any suggestion on setting one like that
>> on my normal OpenLayers Map ??
>> Cheers,
>> Kalyan
>> On Mon, Aug 16, 2010 at 11:08 PM, BMcBride <bmcbride at chacompanies.com>
>> wrote:
>> Hi Philippe,
>> I have put together some
>> http://www.bryanmcbride.com/blog/geoexplorer_hacks_2 documentation for
>> implementing similar "Quick Zooms" in GeoExplorer. GeoExplorer is a
>> component of the http://opengeo.org/community/suite/ OpenGeo Suite ,
>> built
>> on OpenLayers and GeoExt. You can see the "Quick Zooms" in action
>> http://www.opengeohost.com/geoexplorer/ here . Hopefully this will get
>> you
>> going in the right direction!
>> BRYAN
>> http://www.bryanmcbride.com bryanmcbride.com
>> http://geoserving.net/ geoserving.net
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/Define-several-states-of-view-Zoom-Area-tp5427671p5427774.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100826/f0af4d08/attachment.html
