[OpenLayers-Users] OpenLayers Book by Jansen and Adams
Maik Juks
jugs at gmx.de
Thu Aug 26 03:17:22 EDT 2010
Hi Marc,
thanks for your hints. I have php installed. Actually I used the MS4W (Mapserver for windows) package.
One thing I tried is:
>From the example code in postgis-terminal.html I changed
action = "./process-spatial-query.php" to action = ""http://localhost/process-spatial-query.php" and the same for the url property in the processSpatialQuery function.
In this case, nothing happens, I get an empty js messagebox.
Regards,
J
-------- Original-Nachricht --------
> Datum: Thu, 26 Aug 2010 07:56:04 +0200
> Von: Marc Jansen <jansen at terrestris.de>
> An: users at openlayers.org
> Betreff: Re: [OpenLayers-Users] OpenLayers Book by Jansen and Adams
> Hi J,
> to run PHP code you have to install PHP. For testing I would suggest
> XAMPP[1], that has a whole bundle of software packed together so that
> everything works.
> Best regards,
> Marc
> J: um PHP ausführen zu können, muss auf Deinem System PHO installiert
> sein. Ich empfehle Dir XAMPP[1], ein komplettes & gut abgestimmtes Packet.
> Grüße,
> Marc
> [1] http://www.apachefriends.org/en/xampp.html
> On 25.08.2010 22:15, jugs at gmx.de wrote:
> > I am developing on a local machine. How can i make the Code being
> interpreted.
> > "Marc Jansen"<jansen at terrestris.de> schrieb:
> >> Hi J,
> >> since you see the PHP-code, it is very likel, that you are running this
> >> example somewhere where PHP isn't being interpreted. Are you developing
> >> on a webserver or locally?
> >> Regards,
> >> Marc
> >> On 25.08.2010 16:15, jugs at gmx.de wrote:
> >>> Sorry for writing in German, but it is a German issue regarding the
> book mentioned above.
> >>> Hallo Liste,
> >>> bin ein Neuling hier und auch in der Thematik.
> >>> Hat jemand das Beispiel 9 aus dem Openlayers Buch von Jansen und Adams
> nachvollzogen. Ich bekomme als Antwort den gesamten Inhalt der php-Datei.
> ich nutze den Quellcode wie im Beispiel.
> >>> Gruss
> >>> J
> >> _______________________________________________
> >> Users mailing list
> >> Users at openlayers.org
> >> http://openlayers.org/mailman/listinfo/users
> > Users mailing list
> Karten im (Inter|Intra)net?
> OpenLayers - Webentwicklung mit dynamischen Karten und Geodaten
> von M. Jansen und T. Adams, OpenSourcePress, München.
> ISBN: 978-3-937514-92-5
> URL: http://openlayers-buch.de
> Dipl.-Geogr. Marc Jansen
> - Anwendungsentwickler -
> terrestris GmbH& Co. KG
> Irmintrudisstraße 17
> 53111 Bonn
> Tel: ++49 (0)228 / 96 28 99 -53
> Fax: ++49 (0)228 / 96 28 99 -57
> Email: jansen at terrestris.de
> Web: http://www.terrestris.de
> Amtsgericht Bonn, HRA 6835
> Komplementärin: terrestris Verwaltungsgesellschaft mbH
> vertreten durch: Hinrich Paulsen, Till Adams
> Users mailing list
GRATIS für alle GMX-Mitglieder: Die maxdome Movie-FLAT!
Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome01
