[OpenLayers-Users] Fwd: Re: OpenLayers Book by Jansen and Adams
Maik Juks
jugs at gmx.de
Thu Aug 26 04:12:42 EDT 2010
this statement works as well:
http://localhost/process-spatial-query.php?command=Select%20St_asText%28St_GeometryFromText%28%27POINT%2810%2010%29%27%2C%204326%29%29
-------- Original-Nachricht --------
> Datum: Thu, 26 Aug 2010 09:21:59 +0200
> Von: jugs at gmx.de
> An: users at openlayers.org
> Betreff: [OpenLayers-Users] Fwd: Re: OpenLayers Book by Jansen and Adams
> Datum: Thu, 26 Aug 2010 09:17:22 +0200
> Von: "Maik Juks" <jugs at gmx.de>
> Betreff: Re: [OpenLayers-Users] OpenLayers Book by Jansen and Adams
> Hi Marc,
> thanks for your hints. I have php installed. Actually I used the MS4W
> (Mapserver for windows) package.
> One thing I tried is - From the example code in postgis-terminal.html I
> changed
> action = "./process-spatial-query.php" to action =
> ""http://localhost/process-spatial-query.php" and the same for the url property in the
> processSpatialQuery function.
> In this case, nothing happens, I get an empty js messagebox.
> Regards,
> J
> > Datum: Thu, 26 Aug 2010 07:56:04 +0200
> > Von: Marc Jansen <jansen at terrestris.de>
> > Hi J,
> > to run PHP code you have to install PHP. For testing I would suggest
> > XAMPP[1], that has a whole bundle of software packed together so that
> > everything works.
> > Best regards,
> > Marc
> > J: um PHP ausführen zu können, muss auf Deinem System PHO installiert
> > sein. Ich empfehle Dir XAMPP[1], ein komplettes & gut abgestimmtes
> Packet.
> > Grüße,
> > Marc
> > [1] http://www.apachefriends.org/en/xampp.html
> > On 25.08.2010 22:15, jugs at gmx.de wrote:
> > > I am developing on a local machine. How can i make the Code being
> > interpreted.
> > > "Marc Jansen"<jansen at terrestris.de> schrieb:
> > >> Hi J,
> > >> since you see the PHP-code, it is very likel, that you are running
> this
> > >> example somewhere where PHP isn't being interpreted. Are you
> developing
> > >> on a webserver or locally?
> > >> Regards,
> > >> Marc
> > >> On 25.08.2010 16:15, jugs at gmx.de wrote:
> > >>> Sorry for writing in German, but it is a German issue regarding the
> > book mentioned above.
> > >>> Hallo Liste,
> > >>> bin ein Neuling hier und auch in der Thematik.
> > >>> Hat jemand das Beispiel 9 aus dem Openlayers Buch von Jansen und
> Adams
> > nachvollzogen. Ich bekomme als Antwort den gesamten Inhalt der
> php-Datei.
> > ich nutze den Quellcode wie im Beispiel.
> > >>> Gruss
> > >>> J
> > >> _______________________________________________
> > >> Users mailing list
> > >> Users at openlayers.org
> > >> http://openlayers.org/mailman/listinfo/users
> > > Users mailing list
> > Karten im (Inter|Intra)net?
> > OpenLayers - Webentwicklung mit dynamischen Karten und Geodaten
> > von M. Jansen und T. Adams, OpenSourcePress, München.
> > ISBN: 978-3-937514-92-5
> > URL: http://openlayers-buch.de
> > Dipl.-Geogr. Marc Jansen
> > - Anwendungsentwickler -
> > terrestris GmbH& Co. KG
> > Irmintrudisstraße 17
> > 53111 Bonn
> > Tel: ++49 (0)228 / 96 28 99 -53
> > Fax: ++49 (0)228 / 96 28 99 -57
> > Email: jansen at terrestris.de
> > Web: http://www.terrestris.de
> > Amtsgericht Bonn, HRA 6835
> > Komplementärin: terrestris Verwaltungsgesellschaft mbH
> > vertreten durch: Hinrich Paulsen, Till Adams
> > Users mailing list
> GRATIS für alle GMX-Mitglieder: Die maxdome Movie-FLAT!
> Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome01
> Neu: GMX De-Mail - Einfach wie E-Mail, sicher wie ein Brief!
> Jetzt De-Mail-Adresse reservieren: http://portal.gmx.net/de/go/demail
> Users mailing list
GMX DSL SOMMER-SPECIAL: Surf & Phone Flat 16.000 für nur 19,99 ¿/mtl.!*
http://portal.gmx.net/de/go/dsl
