[OpenLayers-Users] Fwd: Re: OpenLayers Book by Jansen and Adams
Maik Juks
jugs at gmx.de
Thu Aug 26 07:32:28 EDT 2010
Thanks Marc. You are right it is not a OL issue. It was me :-)
I opened the html in a browser --> not working.
using localhost for accessing the html document solved the problem.
btw: Great book!
-------- Original-Nachricht --------
> Datum: Thu, 26 Aug 2010 12:44:01 +0200
> Von: Marc Jansen <jansen at terrestris.de>
> An: users at openlayers.org
> Betreff: Re: [OpenLayers-Users] Fwd: Re: OpenLayers Book by Jansen and Adams
> Hi Maik,
> if the URL below works, everything else (including these
> http://openlayers-buch.de/beispiele/chapter-09/nice-queries-for-postgis-console.sql)
> should work.
> As this is not directly related to OpenLayers -- it is very likely not
> an OpenLayers issue/problem you have -- I suggest taking this offlist
> from now on.
> Regards,
> Marc
> On 26.08.2010 10:12, Maik Juks wrote:
> > this statement works as well:
> http://localhost/process-spatial-query.php?command=Select%20St_asText%28St_GeometryFromText%28%27POINT%2810%2010%29%27%2C%204326%29%29
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
GMX DSL SOMMER-SPECIAL: Surf & Phone Flat 16.000 für nur 19,99 ¿/mtl.!*
http://portal.gmx.net/de/go/dsl
