[OpenLayers-Users] OpenLayers.Control.SelectFeature with
highlight, toggle
Eric Lemoine
eric.lemoine at camptocamp.com
Fri Aug 27 09:58:45 EDT 2010
On Fri, Aug 27, 2010 at 3:37 PM, Christian Niemitz-Rossant
<cnr at m-click.de> wrote:
> Hi Eric,
> after filing the ticket
> http://trac.openlayers.org/ticket/2812
> I got a message from Ilias, because he had to deal with the same problem.
> His solution to add to the selectCtrl an onUnselect and in this function to
> call
> highlightCtrl.unhighlight(feature);
> works fine for me. The two controls interfere and by calling a function of
> one in the other solves the problem. Anyway I think that a solution of only
> one control for highlight and select might be valuable, or?
> Otherwise an example for this problem should be under examples and I would
> be happy to provide it.
Hi. I just attached a patch to the ticket. Could you tell if it works
for you, and comment back in the comment please? Thanks.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
