[OpenLayers-Users] WMS layers and Gmaps V3 with OL 2.9.1
Bart van den Eijnden
bartvde at osgis.nl
Sun Aug 29 04:12:06 EDT 2010
There is not Google V3 support in 2.9.1.
Try 2.10 RC1.
Best regards,
Bart
Looking for flexible support on OpenLayers or GeoExt? Please check out http://www.osgis.nl/support.html
OSGIS
bartvde at osgis.nl
On Aug 29, 2010, at 6:38 AM, P Kishor wrote:
> I have the following, simplest possible code. Works without gmaps
> layer, but no WMS shows up when gmaps layer is included. What is it
> that I am doing wrong?
> <script type="text/javascript">
> function init(){
> var lon = -90.397;
> var lat = 45.93;
> var zoom = 5;
> var map = new OpenLayers.Map( 'map' );
> var layer = new OpenLayers.Layer.WMS(
> "OpenLayers WMS",
> "http://labs.metacarta.com/wms/vmap0",
> {layers: 'basic'}
> var counties = new OpenLayers.Layer.WMS(
> "Counties",
> "http://mapserv.ssec.wisc.edu/cgi-bin/mapserv?map=/opt/fgs/www/htdocs/research/Projects/LakesTSI/lakestsi2.map",
> layers: "Counties",
> map_imagetype: "agga",
> transparent: true,
> reproject: true,
> singleTile: true
> var gphy = new OpenLayers.Layer.Google(
> "Google Physical",
> {type: google.maps.MapTypeId.TERRAIN}
> // the following doesn't work
> map.addLayers([gphy, counties]);
> // the following works fine
> map.addLayers([layer, counties]);
> map.setCenter(new OpenLayers.LonLat(lon, lat).transform(
> new OpenLayers.Projection("EPSG:4326"),
> map.getProjectionObject()
> ), zoom);
> map.addControl( new OpenLayers.Control.LayerSwitcher() );
> </script>
> Puneet Kishor
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
