[OpenLayers-Users] inconsistency in control syntax
Bart van den Eijnden
bartvde at osgis.nl
Sun Aug 29 04:14:33 EDT 2010
Right, the constructor for the Scale Control is a bit different:
* Constructor: OpenLayers.Control.Scale
* Parameters:
* element - {DOMElement}
* options - {Object}
initialize: function(element, options) {
OpenLayers.Control.prototype.initialize.apply(this, [options]);
this.element = OpenLayers.Util.getElement(element);
So try:
new OpenLayers.Scale(document.getElementById("scale"))
I'll file a bug so we fix this up in 3.0. Thanks for the report.
Bart
Looking for flexible support on OpenLayers or GeoExt? Please check out http://www.osgis.nl/support.html
OSGIS
bartvde at osgis.nl
On Aug 29, 2010, at 7:00 AM, P Kishor wrote:
> // the following works
> var cs = new OpenLayers.Control.Scale();
> cs.div = document.getElementById("scale");
> this.map.addControl(cs);
> // The following also works
> this.map.addControl(new OpenLayers.Control.MousePosition({div:
> document.getElementById("coords")}));
> // The following does not work. Why?
> this.map.addControl(new OpenLayers.Control.Scale({div:
> document.getElementById("scale")}));
> Puneet Kishor
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
