[OpenLayers-Users] WFS-T Update problem,
wrong SRID for changed geometry
paweluz
paweluz at o2.pl
Thu Feb 4 05:16:42 EST 2010
Hi
I have problem with WFS-T when I update geometry on map. I am using OL 2.8,
Geoserver 1.6.4 and PostgreSQL8.3 with Postgis 1.3.6. I am using google
layer as a base layer.
When I update the geometry on map and do commit() the geometry disappears! I
did not know what was happening until I check my database. Al my data are in
SRID 4326. When I execute SQL query "Select astext(the_geom) from my_table"
I got one geometry that is so much different from the other. It was a
geometry in google SRID. Why??? I check everything in QuantumGIS and my
changed geometry is far, far away from the place I wanted it to be.
I am also using WFS to add new data to database and there everything works
just fine!!
For update I am using feature.state = OpenLayers.State.UPDATE;
For adding I am using feature.state = OpenLayers.State.INSERT;
My WFS definition is
zielona_wfs = new OpenLayers.Layer.WFS(
"Zielona Gora WFS - drogi, postgis",
"http://localhost:8080/geoserver/wfs?",
{typename: 'topp:zielona_openstreets'},
typename: 'zielona_openstreets',
featureNS: 'http://www.openplans.org/topp',
styleMap: wfs_style,
srs: 'EPSG:4326',
extractAttributes: true
Does anyone know what is wrong? Maybe there is a way to change the srs for
geometry that is being changed?
Regards,
Poul
View this message in context: http://n2.nabble.com/WFS-T-Update-problem-wrong-SRID-for-changed-geometry-tp4512597p4512597.html
