[OpenLayers-Users] Google Overviewmap
JuKiM rifins at gmail.com
Fri Feb 5 09:27:12 EST 2010
It doesn't works for me..
For a high zoom level, the center of the base layer and the center of the
overview are very similar, but as I got lower zoom levels and showing more
map, it seems like the center of the base layer is more to the north-west
than the center of the overview.. And in each refresh of overview map zoom
level the diference between both centers increases..
Can be a problem with projections maybe?
Thanks!
2010/2/5 Max Weidemann <max.weidemann at freenet.de>
> I think it is a bug in Openlayers. I described it here
> if you call the maximizeControl Function after you add the Control and set
> spherical Mercator to true it will work.
> map.addControl(overview);
> overview.maximizeControl();
> http://n2.nabble.com/Google-Overviewmap-tp4519147p4520026.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100205/ab52454e/attachment.html
