[OpenLayers-Users] Magnifier window
Steve.Toutant at inspq.qc.ca
Fri Feb 5 09:29:56 EST 2010
Almost done....Amasing how things are easy to do with OL.
I have a wms layers array, "overlays[]"
I use this code to create the layers array of the overview map and to
define the visibilitychanged event.
var addLayersToMap = function()
for( i in overlays )//overlays contains my wms layers
map.addLayer( overlays[i] );
ov_overlays[i] = overlays[i].clone();
ov_map.addLayer( ov_overlays[i] );
//Ajoute un listener au niveau de la carte principal pour gérer
l'affichage sur la ov_map
overlays[i].events.on(
'visibilitychanged': function(event)
ov_overlays[i].setVisibility(overlays[i].getVisibility());
in run time, only the visibility of the last layer of the array gets
updated in the other map.
I also tried with map.addLayers after adding the overlays[i]. events
on...with the same result
Do you see something wrong
thanks
Steve
Alexandre Dube <adube at mapgears.com>
04/02/2010 03:36 PM
A
cc
users at openlayers.org
Objet
Re: [OpenLayers-Users] Magnifier window
Hi Steve,
I think you could do something like that (pseudo-code) :
Create your original map
Create all your layers and add them to the map
Create your ov-map
Register a mapmove event to the map to make ov-map follow it
For each layer
Clone it and add it to ov-map
Register a visibilitychange event to a onVisibilityChanged function
onVisibilityChanged: function(event)
var layers = ov-map.getLayersByName(this.name); // this is the layer
the visibility was changed
if(layers && layers.length == 1)
layers[0].setVisibility(this.visibility())
Do you get the idea ?
Best regards,
Alexandre
Steve.Toutant at inspq.qc.ca wrote:
> Hi,
> I'm using openlayers with geoext.
> I would like to create a magnifier window. So it is like an overview
> map with a fix map center and a fix zoom level, but the main map and
> this overview map share the same geoext tree, so the layers are
> shown/hidden on both maps.
> I think I can do it if I start with the overview map example, here
> http://www.openlayers.org/dev/examples/example-list.html
> Does someone have a better idea or already tried this?
> thanks in advance
> Steve
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100205/8368a353/attachment.html
