[OpenLayers-Users] WFSDescribeFeatureType with complex type element
ref
HKChad
forums at 2kgt.com
Mon Feb 8 17:22:23 EST 2010
I have a WFS that includes some complex types as element ref's in the schema.
The WFSDescribeFeatureType parser is choking on them and throwing the error
'TypeError: fullType.split is not a function'. I have a sample here,
http://www.2kgt.com/test/WFSDescribeFeatureType.html
The error gets thrown on line 119 in the file above where I call, res2 =
parser.read(broken);
My schema that I'm trying to parse contains many more of these types but the
samples I have provided demonstrate the issue that I'm running into. The
'<xsd:element ref="iwfs:DDMS_CREATOR"/>' is where I believe the parser is
having troubles.
I tried to look through the WFSDescribeFeatureType.js but couldn't figure
out what needed to be changed to get it to recognize these complex ref's.
Any help would be appreciated.
Thanks,
Chad
View this message in context: http://n2.nabble.com/WFSDescribeFeatureType-with-complex-type-element-ref-tp4537546p4537546.html
