[OpenLayers-Users] Possible bug with Protocol.WFS
Andreas Hocevar
ahocevar at opengeo.org
Tue Feb 9 03:45:24 EST 2010
Brian Stempin wrote:
> I've been working with a few people on #openlayers to help me out with
> a WFS issue. I'm posting this to the list because I may have found a
> bug in the process.
> protocol:new OpenLayers.Protocol.WFS({
> version: "1.1.0",
> //url: "test.xml",
> // modified by bstempi
> url: "/geoserver/wms",
> featureType: "v_stats_20090101_000000",
> featureNS: "http://192.168.0.20/geoserver/wms",
> geometryName: "the_geom"
> I found that the above code will work if you add srsName:
> "EPSG:900913" to the WFS options.
> Is this a feature/bug/magic, or me being silly?
You mean it works if you add that to the protocol options, right? That's
the way it is done. The BBOX strategy will use map coordinates
(EPSG:900913), and the protocol would think they are in the default SRS
for the feature type if you don't tell it what the SRS is.
Regards,
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
