[OpenLayers-Users] Possible bug with Protocol.WFS
Tim Schaub
tschaub at opengeo.org
Tue Feb 9 11:58:44 EST 2010
Tim Schaub wrote:
> Andreas Hocevar wrote:
>> Hi,
>> Brian Stempin wrote:
>>> I've been working with a few people on #openlayers to help me out with
>>> a WFS issue. I'm posting this to the list because I may have found a
>>> bug in the process.
>>> protocol:new OpenLayers.Protocol.WFS({
>>> version: "1.1.0",
>>> //url: "test.xml",
>>> // modified by bstempi
>>> url: "/geoserver/wms",
>>> featureType: "v_stats_20090101_000000",
>>> featureNS: "http://192.168.0.20/geoserver/wms",
>>> geometryName: "the_geom"
>>> I found that the above code will work if you add srsName:
>>> "EPSG:900913" to the WFS options.
>>> Is this a feature/bug/magic, or me being silly?
>> You mean it works if you add that to the protocol options, right? That's
>> the way it is done. The BBOX strategy will use map coordinates
>> (EPSG:900913), and the protocol would think they are in the default SRS
>> for the feature type if you don't tell it what the SRS is.
> Right. Sorry I stopped short of making it work for your WFS (as an
> aside, though GeoServer is lenient with your /geoserver/wms url above,
> it might be less misleading to use /geoserver/ows or /geoserver/wfs - no
> real difference if you are sending the SERVICE parameter, but it is less
> confusing to the reader).
> One way you could have determined what was wrong was to examine the
> outgoing GetFeature request. In Firebug, you should see the POST
> request being issued. Looking at the body of the request, I imagine
> you'll see an element representing the bounding box with an srsName
> attribute of "EPSG:4326". It is a shortcoming of the protocol that it
> doesn't try to guess the srsName from the layer projection. I'll ticket
> this.
Scratch that. The protocol doesn't know about the layer. Hmmmm.
> In the meantime, you should set srsName explicitly in the protocol
> options if it differs from "EPSG:4326". The reason it is settable
> (instead of always derived from the layer projection) is that some
> servers may require an srsName that cannot be derived from the layer
> projection (as things currently stand).
> Thanks for the patience.
> Tim
>> Regards,
>> Andreas.
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
