[OpenLayers-Users] Drawing and labelling a circle in OL 2.7
Andreas Hocevar ahocevar at opengeo.org
Wed Feb 10 03:47:48 EST 2010
for drawing a circle you would use a DrawFeature control with a
RegularPolygon handler. See
http://www.openlayers.org/dev/examples/regular-polygons.html for an example.
Labeling features is possible, but requires at least OpenLayers 2.8. See
http://www.openlayers.org/dev/examples/vector-features-with-text.html
for an example.
Upgrading to a more recent version of OpenLayers should not cause you
any big trouble.
Regards,
Andreas.
jbloc1878 at googlemail.com wrote:
> Hi does anyone have a code example of drawing a circle within open
> layers 2.7? I was Reading through the open layers documentation but
> cannot get it to work, also I am not sure if it is only for 2.8.
> Also is it possible to label the circle with some text? Or any shape for
> that matter polygon or line?
> Thanks for any help in advance
> Jay
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
