[OpenLayers-Users] layer loadend event
protos kildimo at gmail.com
Wed Feb 10 05:49:12 EST 2010
In case anyone is interested - this is what I did to get around the loadend
bug :
    checkBaseLayerReady: function(map) {
        if (!map.baseLayer) {
            return false;
        else {
            var ldiv = map.baseLayer.div;
            var flag = true;
            for (var k = 0, len = ldiv.childNodes.length; k < len; k++) {
                var node = ldiv.childNodes[k];
                if (!node.complete) {
                    flag = false;
            return flag;
    checkAndClearCloneLayer:function(map){
        console.debug ("Checking and clearing Cloned Layer.");
        if(!map){
            map = this.map;
        if (map){
        // OL loadend event gets fired too early so we need
        // this to check if indeed the new baseLayer is fully loaded.
            var retrier = new PeriodicalExecuter(function(pe) {
                if (this.checkBaseLayerReady(map)) {
                    if (map.baseLayerClone){
map.layerContainerDiv.removeChild(map.baseLayerClone.div);
                        if (Prototype.Browser.IE) {
                            map.baseLayerClone.outerHTML = "";
                        map.baseLayerClone.grid = null;
                        map.baseLayerClone = null;
                        pe.stop();
            }.bind(this), 0.1);
View this message in context: http://n2.nabble.com/layer-loadend-event-tp4533615p4547100.html
