[OpenLayers-Users] Can't update a feature for which there is no
FID (WFS-T)
Eric Lemoine
eric.lemoine at camptocamp.com
Wed Feb 10 12:15:28 EST 2010
On Wednesday, February 10, 2010, paweluz <paweluz at o2.pl> wrote:
> Hi!
> I have problem with WFS-T ADD state. I my application the user is able to
> add, update and delete a feature from map. The problem appears if:
> 1. User draw new geometry on map, fill out the attributes of new object and
> click SAVE to database.
> 2. Then user click on the new object on map. The attributes of the object
> appear.
> 3. User is trying to modify or delete the object... Then I got an alert
> Can't update a feature for which there is no FID
> I check it in firebug, and the FID is null. Why is that... The real funny
> think is that when I change the zoom of the map, or click F5, or in layer
> switch a uncheck and check my wfs_layer, the FID of my new object is changed
> to correct!! Now the user is able to remove or change the geometry (object)
> on map. Did anyone have this problem?
> Here is code for adding new object into the database
> feature.layer.eraseFeatures([feature]);
> feature.geometry = new OpenLayers.Geometry.MultiLineString(
> feature.geometry
> selectedfeature=feature;
> feature.state = OpenLayers.State.INSERT;
> feature.layer.drawFeature(feature);
> my_wfslayer.commit();
> If I add the line my_wfslayer.refresh(); at the end I got response
> (SUCCEED), my layer is refreshed but I can't see my new object (new geometry
> does not appear on map). I have to click F5 or zomm in/out or make change in
> layer switch(off/on)... What is wrong?
Are you using Layer.WFS or Layer.Vector? Using the latter is
recommended. In your case you'd use it with a Strategy.Save and a
Protocol.WFS configured into it. The Strategy.Save should take care of
updating the features' fid once the create operation is complete.
Check out the WFS examples for more practical information.
Cheers,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
