[OpenLayers-Users] OpenLayers + MapServer + Own maps
showing miniature tiles
Henrik Collin
hcollin78 at googlemail.com
Fri Feb 12 09:14:02 EST 2010
I changed the maxExtent and Resolution and it did some good.
This is how it looks now:
maxResolution: 20000,
maxExtent: new OpenLayers.Bounds(-20037508.34, -20037508.34, 20037508.34,
20037508.34)
The scale of the map is 1:20000 in meters and that Extent is the max extent
of the epsg:2393. It now draws a box into the map with the background color
defined in the wms.map and the dots I am drawing are in a correct place in
this box. The actual map pictures are still drawn way out of bounds and they
are still too small.
Am I using the maxResolution correctly? And if not how am I able figure out
the correct resolution?
I also played with the x_0 definitions in the wms.map and that did move the
map, but that is fake solution as far as I am aware.
Thanks in advance!
Christopher Schmidt-2 wrote:
> On Fri, Feb 12, 2010 at 12:14:46AM -0800, Henrik Collin wrote:
>> Hello,
>> I am currently trying to build a service that shows a map in a webpage
>> with
>> OpenLayers. The OpenLayers requests the map data from MapServer by using
>> WMS
>> and then draws some features in a layer on top of the map data.
>> My main problem is that the loaded map shows as a tiny dot in the screen
>> until I zoom enough. This would be okay if the features would be drawn
>> correctly on the map but alas they are not. They are off from the
>> position
>> thousands of kilometres. My features are in projection EPSG4326 which is
>> converted to EPSG2393 the map uses. Projections have been setup in both
>> systems MapServer and OpenLayers.
>> The map consists of multiple tiles that have been combined to shapefile
>> with
>> MapServers shp2img.exe. When I request the map file form the browser it
>> works perfectly. It returns me the correct piece of the map in the
>> correct
>> tile size.
>> Does anyone have any idea what am I doing wrong? This is my first try
>> with
>> both services OpenLayers and MapServer so I am not quite sure which one
>> is
>> causing the problems, but as the MapServer returns a correct result when
>> quering directly my educated guess is that the problem lies in the
>> OpenLayers side.
> Your maxExtent and maxResolution are wrong, and unset, respectively.
> You'll need to fix that.
> -- Chris
>> I originally tried the OpenLayers side with Google Maps and got that
>> working
>> ok.
>> _____________________________________________________________________________________
>> HTML (In Header):
>> <script type="text/javascript"
>> src="js/openlayers/OpenLayers.js"></script>
>> <script type="text/javascript" src="js/proj4js/proj4js.js"></script>
>> src="js/proj4js/defs/EPSG2393.js"></script>
>> src="js/proj4js/defs/EPSG4326.js"></script>
>> src="js/proj4js/defs/EPSG900913.js"></script>
>> OPENLAYERS: (This is not a direct copy of the code as the actual code is
>> written inside multiple MooTools classes and contains a lot of code not
>> needed in here.)
>> var mapOptions = {
>> projection: new OpenLayers.Projection("EPSG:2393"),
>> units: "m",
>> // maxResolution: 156543.0339,
>> 20037508.34, 20037508.34)
>> var x = 23;
>> var y = 60;
>> var pos = {
>> lat: x,
>> lon: y,
>> zoom: 6
>> Method from a class responsible for loading the layers and initializing
>> the
>> map.
>> loadMap: function() {
>> // Create map layer
>> this.map = new OpenLayers.Map(paneMain, mapOptions);
>> this.map.addControl(new OpenLayers.Control.NavToolbar());
>> this.gphy = new OpenLayers.Layer.Google(
>> "Google Physical",
>> {type: G_PHYSICAL_MAP, sphericalMercator: true}
>> this.map.addLayer(this.gphy);
>> this.wmsserv = new OpenLayers.Layer.WMS(
>> "WMS Server",
>> "http://localhost:591/cgi-bin/mapserv.exe?map=/ms4w/apps/service/wms.map&",
>> layers: "Kartta",
>> SRS: "EPSG:2393",
>> format: "image/png"
>> { isBaseLayer: true }
>> this.map.addLayer(this.wmsserv);
>> // Add Vector Layer on top of the map layer
>> var vectorStyleMap = new OpenLayers.StyleMap({
>> graphicZIndex: 100
>> this.layerLines = new OpenLayers.Layer.Vector("Line Layer", {
>> styleMap:
>> vectorStyleMap, rendererOptions: { zIndexing: true } });
>> this.map.addLayer(this.layerLines);
>> // Add layer controls
>> selectControl = new OpenLayers.Control.SelectFeature(
>> this.layerLines,
>> clickout: true, toggle: true,
>> multiple: false, hover: false,
>> onSelect: this.LineClick,
>> onUnSelect: this.LineUnSelect
>> this.map.addControl(selectControl);
>> selectControl.activate();
>> this.map.events.register("zoomend", this, function(e) {
>> this.redrawDots();
>> // Center the map
>> var centerPos = new OpenLayers.LonLat(pos.lon, pos.lat).transform(new
>> OpenLayers.Projection("EPSG:4326"), new
>> OpenLayers.Projection("EPSG:2393"));
>> this.map.setCenter(centerPos, this.pos.zoom, false, false);
>> WMS.MAP (Settings in the MapServer side)
>> MAP
>> NAME "Service"
>> STATUS ON
>> SIZE 256 256
>> IMAGECOLOR 128 128 192
>> # EXTENT 2417774 6720000 2430000 6730000 # Koko kartta
>> # EXTENT 2427774 6724000 2429000 6726000 # Zoom
>> # EXTENT 3050187.8969 6585228.0377 3761549.0272 7803095.3519
>> IMAGETYPE PNG
>> UNITS METERS
>> SHAPEPATH "maps/"
>> PROJECTION
>> "init=epsg:2393"
>> # "proj=tmerc"
>> # "lat_0=0"
>> # "lon_0=27"
>> # "k=1"
>> # "x_0=3500000"
>> # "y_0=0"
>> # "ellps=intl"
>> "towgs84=-96.0617,-82.4278,-121.7435,4.80107,0.34543,-1.37646,1.4964"
>> # "units=m"
>> # "no_defs"
>> END
>> WEB
>> IMAGEPATH "/ms4w/tmp/ms_tmp/"
>> IMAGEURL "/ms_tmp/"
>> TEMPLATE "service.html"
>> LOG "service.log"
>> METADATA
>> "wms_title" "Service"
>> "wms_onlineresource"
>> "wms_srs" "EPSG:4022"
>> END
>> END
>> LAYER
>> NAME "Kartta"
>> METADATA
>> "wms_title" "Map layer"
>> END
>> TYPE RASTER
>> STATUS ON
>> TILEINDEX "testshape.shp"
>> DUMP TRUE
>> PROJECTION
>> "init=epsg:2393"
>> # "proj=tmerc"
>> # "lat_0=0"
>> # "lon_0=27"
>> # "k=1"
>> # "x_0=3500000"
>> # "y_0=0"
>> # "ellps=intl"
>> # "units=m"
>> # "no_defs"
>> END
>> END
>> END
>> View this message in context:
>> http://n2.nabble.com/OpenLayers-MapServer-Own-maps-showing-miniature-tiles-tp4559876p4559876.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Christopher Schmidt
> MetaCarta
> Users mailing list
View this message in context: http://n2.nabble.com/OpenLayers-MapServer-Own-maps-showing-miniature-tiles-tp4559876p4561208.html
