[OpenLayers-Users] Show polygon vertices?
Maxime Phaneuf maxime.phaneuf at usherbrooke.ca
Tue Feb 16 08:54:59 EST 2010
Hi
Yes it is possible,
You juste have to create a modify control and select the feature you want to
modify. Just take a look at this example:
http://dev.openlayers.org/releases/OpenLayers-2.8/examples/modify-feature.html
Good luck
Maxime
View this message in context: http://n2.nabble.com/Show-polygon-vertices-tp4580179p4580312.html
